Nokia LCD on Arduino Mini Pro:SDATA has to be PWM or not?
hi fellas,
im working on a bluetooth wrist watch project.
here you can see some photos:
http://www.flickr.com/photos/mclightning/
It is almost finished but i have one problem left...
I tested Nokia LCD(Sparkfun Nok.Lcd) with Arduino Duemilenova it was working just fine...
Then i soldered circuit onto veroboard of my watch. But LCD didnt display :confused: It just lights up but no display what so ever...
Here how i connected LCD to Arduino Mini Pro:
#define CS 9
#define CLK 8
#define SDA 10
#define RESET 7
and here is the code :
http://pastebin.com/Sw13wdz5
I can't open the code file (proxy thing), but
CLK & SDA sound like I2C lines - if so, those have to come from specific hardware pins, A4 & A5.
How were they connected on the Duemilanove?
If they worked with D7,8,9,10 there, they would work with D7,8,9,10 on the Promini as well.
on Arduino Duemilenova it was working as:
#define CS 4
#define CLK 5
#define SDA 6
#define RESET 7
on Pro Mini it is not working (just powers up backlight) as :
#define CS 9
#define CLK 8
#define SDA 10
#define RESET 7
I tested those pins on Pro Mini. there is no misconnection :confused: tested led blink by connecting 2 leds to 8-9 & 7-10 it worked just fine so i guess there is nothing wrong with soldering
none have an idea???
In void setup,
427. void setup()
428.{
429.  DDRD |= B01111100;   // Set SPI pins as output
430.  PORTD |= B01111100;  // Set SPI pins HIGH
 431. lcd_init();
 432.   delay(500);
 433.   lcd_clear(BLACK,0,0,131,131);
 434.   pinMode(1,OUTPUT);
 435.   pinMode(3,OUTPUT);
 436.   digitalWrite(1,LOW);
 437.   digitalWrite(3,HIGH);
 438. }
One usually uses pinMode to declare pins as inputs or outputs.
You have nothing here for these pins, which may only mean I don't know much about cryptic C code. One of the reasonsI like the Arduino IDE, much easier to follow.
#define CS    9
#define CLK   8
#define SDA   10
#define RESET 7
Somehow the signals are tied in here also
#define CS0 cbi(PORTD,CS);
#define CS1 sbi(PORTD,CS);
#define CLK0 cbi(PORTD,CLK);
#define CLK1 sbi(PORTD,CLK);
#define SDA0 cbi(PORTD,SDA);
#define SDA1 sbi(PORTD,SDA);
#define RESET0 cbi(PORTD,RESET);
#define RESET1 sbi(PORTD,RESET);
#define BL0 cbi(PORTD,BL);
#define BL1 sbi(PORTD,BL);
So maybe thats the clue:
#define CS 4
#define CLK 5
#define SDA 6
#define RESET 7
4-5-6-7 are all PortD pins
#define CS 9
#define CLK 8
#define SDA 10
#define RESET 7
and 8-9-1 are PortB pins.
i guess you are right sir :slight_smile:
i did same pin connection on arduino duemilenova and it didnt work on duemilenova too :slight_smile:
i'll change the pin connections on pro mini to the working combination asap and i'll let you know the result :slight_smile:
Thank you so much for the help :slight_smile:
Glad to help.
thank you so much again :slight_smile:
i just tested on Arduino Mini Pro and it worked :slight_smile:
