NON AGGIORNATE AVR-GCC!! leggere
Oggi dopo qualce giorno in montagna ho ripreso in mano arduino... peccato che ad ogni compilazione mi compare l'errore:
In file included from /home/mauro/arduino-0022/hardware/arduino/cores/arduino/Tone.cpp:37:0:
/home/mauro/arduino-0022/hardware/arduino/cores/arduino/pins_arduino.h:66:48: error: variable 'port_to_mode_PGM' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
/home/mauro/arduino-0022/hardware/arduino/cores/arduino/pins_arduino.h:67:49: error: variable 'port_to_input_PGM' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
/home/mauro/arduino-0022/hardware/arduino/cores/arduino/pins_arduino.h:68:50: error: variable 'port_to_output_PGM' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
/home/mauro/arduino-0022/hardware/arduino/cores/arduino/pins_arduino.h:70:54: error: variable 'digital_pin_to_port_PGM' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
/home/mauro/arduino-0022/hardware/arduino/cores/arduino/pins_arduino.h:72:58: error: variable 'digital_pin_to_bit_mask_PGM' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
/home/mauro/arduino-0022/hardware/arduino/cores/arduino/pins_arduino.h:73:55: error: variable 'digital_pin_to_timer_PGM' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
/home/mauro/arduino-0022/hardware/arduino/cores/arduino/Tone.cpp:108:45: error: variable 'tone_pin_to_timer_PGM' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
ho provato a riscaricare l'IDE, ma non ha sortito alcun effetto.. ho fatto qualche aggiornamento, ma non ricordo se gcc o simili erano inclusi... ecco le versioni dei software gcc (GCC) 4.6.1 gcc-avr 4.6.1-1 binutils-avr 2.21-1 avr-libc 1.7.0-1 arduino-0022
ora provo a sistemare a mano i suddetti file.
edit: a quanto pare è un bug di avr-gcc, non sono l'unico ad avere lo stesso problema (questa volta il tasto cerca ha fallito, ma ha rimediato google :D ): http://arduino.cc/forum/index.php/topic,66710.0.html
Ma che distro usi, scusa?
E’ molto importante saperlo.
l'errore è di avr-gcc, non della distro... in base alla rapidità con cui le distro accettano gli aggiornamenti dei pacchetti tutte saranno affette, se non esce prima una patch. comunque arch linux
Mi riferivo proprio alla rapidità nell'aggiornare i pacchetti. Cmq distro rolling-release sono più soggette rispetto ad altri a "vivere" i bug di gioventù.
Di solito infatti le distro maggiori aggiornano i pacchetti base più importanti solo al cambio di major release.
PS: io ho dovuto togliere Arch perché avevo il problema di avr-binutils che non creava codice compilato correttamente (vedi bug di delay() ed altri). Ma la cosa è stata risolta o no? Nel link che hai postato ufficialmente mi pare di aver capito di no, e solo con una versione patchata è stato temporaneamente sistemato il problema. O sbaglio io?
boh, sinceramente non sapevo nemmeno di questo bug... per scrupolo ho controllato (evito come la peste i delay per principio) e funziona, arch 32bit e atmega328 con vecchio boot-loader
leo72: Di solito infatti le distro maggiori aggiornano i pacchetti base più importanti solo al cambio di major release.
Ho Ubuntu, Debian e CentOS ferme a gcc4.4, gcc-avr4.3, binutils2.20, avr-libc1.6 e non ho nessun problema. L'unica cosa che ho notato è che con Arduino 0018 installato da pacchetto i binari escono più grossi che con Arduino 0022(es 18k anziché 17.2k) Ciao
MGuruDC:
non devi installare l'IDE dal repository perchè è un IDE vecchio e pieno di BUG
@lesto: è un bug vecchio, risale almeno ad inizio anno. Forse ultimamente i manutentori di avr-binutils hanno provveduto ad applicare le suddette patch di Debian, che sono poi il motivo che mi hanno spinto a rimettere Ubuntu perché questo SO, derivando da Debian, le integra di suo mentre su Arch, seguendo le (confuse e poche) guide in merito su come applicare queste patch ai pacchetti, non ero riuscito a far funzionare la cosa.
Tornando ai pacchetti, queste sono le mie versioni (Xubuntu 11.04): gcc: 4.5.2 avr-gcc: 4.3.5 binutils-avr: 2.20.1 avr-libc: 1.6.8
@superlol: Confermo.
Ho appena visto che nelle repository c'è la 0022 e non più la 0018, comunque sul mio vecchio ubuntu 10.04 non si è aggiornata. In ogni caso l'avevo istallata per "curiosità", non la uso... però non dà problemi. Ciao
dopo accendo il portatile e vedo pure io se su ubuntu 10.04 hanno aggionato
