its a large file … but here’s some of the MotionData which inherits classBitHandler.
classBitHandler manipulates the bits of an unsigned long integer to compress data into 32 bit collections as seen in the first two methods of the MotionData class which sets/gets the Point(byte,byte) value of a value call Loc[ation]. the map size is 32/32 so 5 bits are used for y[0-4] and 5 bits for x[5-9].
class classBitHandler
public:
byte getByte(const unsigned long *ulngData, byte bytBitStart, byte bytBitEnd);
void setBits(unsigned long *ulngData, byte bytBitStart, byte bytBitEnd, byte bytDataIn);
byte classBitHandler::getByte(const unsigned long *ulngData, byte bytBitStart, byte bytBitEnd)
unsigned long ulngTemp = *ulngData >> bytBitStart;
byte bytTemp = 0;
byte bytNumBits = bytBitEnd - bytBitStart + 1;
for (byte bytCounter = 0; bytCounter < bytNumBits; bytCounter ++)
if (ulngTemp % 2 == 1)
bytTemp += (1 << bytCounter);
ulngTemp = ulngTemp >> 1;
return bytTemp;
void classBitHandler::setBits(unsigned long *ulngData, byte bytBitStart, byte bytBitEnd, byte bytDataIn)
unsigned long ulngRetVal = *ulngData;
for (short shCounter = 0; shCounter < 32; shCounter ++)
bool bolShiftIn = false;
if (shCounter >= bytBitStart && shCounter <= bytBitEnd)
bolShiftIn = (bytDataIn % 2) == 1;
bytDataIn = bytDataIn >> 1;
bolShiftIn = (ulngRetVal % 2) == 1;
ulngRetVal = ulngRetVal >> 1;
if (bolShiftIn)
ulngRetVal = ulngRetVal + ((unsigned long)1 << 31);
*ulngData = ulngRetVal;
uses 32 bit unsigned long integer to store :
bits 0-4 Map Current Location Y (range from 0-31)
bits 5-9 Map Current Location X (range from 0-31)
bits 10-14 Map Previous Location Y (range from 0-31)
bits 15-19 Map Previous Location X (range from 0-31)
bits 20, 21 Screen Current Location Y (range from 0-3)
bits 22, 23, 24 Screen Current Location X (range from 0-7)
bits 25, 26 Screen Previous Location Y (range from 0-3)
bits 27, 28, 29 Screen Previous Location X (range from 0-7)
bits 30, 31 direction of motion where 00 = Left, 01 = right, 10 = up & 11= down
class MotionData: classBitHandler
public :
MotionData();
Point Loc_Get();
void Loc_Set(Point ptLocNew);
Point LocPrev_Get();
void LocPrev_Set(Point ptLocPrevNew);
Point ScreenLoc_Get();
void ScreenLoc_Set(Point ptScreenLocNew);
Point ScreenLocPrev_Get();
void ScreenLocPrev_Set(Point ptScreenLocPrevNew);
byte Dir_Get();
void Dir_Set(byte bytDirNew);
unsigned long ulngData;
private:
MotionData::MotionData() {}
Point MotionData::Loc_Get()
byte bytX = MotionData::getByte(&ulngData, 5, 9);
byte bytY = MotionData::getByte(&ulngData, 0, 4);
return Point(bytX, bytY);
void MotionData::Loc_Set(Point ptLocNew)
MotionData::setBits(&ulngData, 5, 9, ptLocNew.X);
MotionData::setBits(&ulngData, 0, 4, ptLocNew.Y);
you can see the player def’n in the previous post and its declaration is
Player player;
[\code]
but the problem is when I try to use the motionData object inside the player object such as
[code]
player.motionData.ScreenLocPrev_Set(ptPlayerScreenLoc);
which is virtually identical to Loc_Set() except the bits sent to classBitHandler’s setBits() function which are described in the commented MotionData description above [25-26 & 27-29] (2 bits to describe the 4 lines available in my 1604 lcd and 3 bits to describe the half width of that same screen)
i don’t understand why the IDE is even mentioning the enumerated type enuMapData in the error I get when I try to compile
request for member ‘motionData’ in ‘player’, which is of non-class type ‘enuMapData’
