Non invasive AC current sensor: how to connect it to the circuit?
Hello,
I have this quite common non invasive AC current sensor (30A version). There's a tutorial here but I don't understand how to connect the sensor because it has a 1/8 (3.5mm) TRS output. The spec sheet tells the two extreme contact points are "output" and the middle point is "vacancy".
Use the two extreme contact points as the output.
Yes, they are the only pins between which I can measure a resistance. However it is strange because I have 37.5 ohms instead of 62 ohms as stated in the spec sheet.
Are you not measuring RL in parallel with the secondary coil of the meter and hence see a lower value ?
Bear in mind this is an AC output too, you cannot connect this directly to an Arduino and must use some form of bias circuit as shown in the example .
amundsen:
I reckon the 62 ohms is the burden resistor, the 37.5 is the burden resistor in parallel with the secondary,
which is an uninteresting parameter as the secondary acts as a current source and its resistance is immaterial.
