[Non résolu] Coffre fort - avec uniquement des boutons
Bonjour,
Je viens d’arriver sur le forum et de commencer la programmation sur arduino.
J’ai tenté de créer un coffre fort, mais il semble que j’ai sûrement commis des erreurs.
Je viens donc quémander votre aide.
Voici mon code :
char ledv = 3;
char buttonUP = 5;
char buttonDOWN = 9;
char buttonLEFT = 13;
char buttonRIGHT = 11;
char button_val = 7;
bool button_stateUP = 0;
bool button_stateDOWN = 0;
bool button_stateLEFT = 0;
bool button_stateRIGHT = 0;
bool button_state_val = 0;
char i = 0;
int code = {0,0,0,0};
int codefin = {1,1,1,1};
pinMode(buttonUP, INPUT);
pinMode(buttonDOWN, INPUT);
pinMode(buttonLEFT, INPUT);
pinMode(buttonRIGHT, INPUT);
pinMode(button_val, INPUT);
pinMode(ledv, OUTPUT);
button_stateUP = digitalRead(buttonUP);
button_stateDOWN = digitalRead(buttonDOWN);
button_stateLEFT = digitalRead(buttonLEFT);
button_stateRIGHT = digitalRead(buttonRIGHT);
if (button_stateLEFT == HIGH)
if (i != 0){
i = i–;
else if (i == 0){
i = 4;
else if (button_stateRIGHT == HIGH)
if (i < 4)
i = i++;
else if ( i == 4)
i = 0;
else if (button_stateUP == HIGH)
if ( i < 9)
code = code*++;*
* Serial.print(code[0]);*
* Serial.print(code[1]);*
* Serial.print(code[2]);*
* Serial.print(code[3]); *
* else if ( i == 9)*
_ code = 0;
}_
else if (button_stateDOWN == HIGH)
_ {
if( i > 0){_
code _= code–;
else if ( i == 0)
code = 9;
void val()
{_
if (button_state_val == HIGH)
_ {_
button_state_val = digitalRead(button_val);
if (button_state_val == HIGH and codefin[0] == code[0])
_ {
Serial.print(“CODE BON”);
else*
Serial.print(“CODE MAUVAIS”);
}*_
[/quote]
Je pense que mon code a un problème au niveau des tableaux mais je ne sais pas lequel.
Merci de votre aide ^^
hello
non testé. attention, serial en 115200
char ledv        =  3;
char buttonUP    =  5;
bool button_stateUP   = false;
bool button_stateDOWN = false;
bool button_stateLEFT = false;
bool button_stateRIGHT= false;
bool button_state_val = false;
byte i = 0;
byte code[] = {0,0,0,0};
byte codefin[] = {1,1,1,1};
  pinMode(buttonUP,   INPUT_PULLUP);
  pinMode(buttonDOWN, INPUT_PULLUP);
  pinMode(buttonLEFT, INPUT_PULLUP);
  pinMode(buttonRIGHT,INPUT_PULLUP);
  pinMode(button_val, INPUT_PULLUP);
  pinMode(ledv, OUTPUT);digitalWrite(ledv,LOW);
      if (i != 0){
        i = i--;
      else if (i == 0){
        i = 3;
        if (i < 3)
        i = i++;
        else if ( i == 3)
        i = 0;
        if ( code[i] < 9)
          code[i]++;
        else if ( code[i] == 9)
          code[i] = 0;
      if( code[i] > 0){
       code[i]--;
      else if ( code[i] == 0)
        code[i] = 9;
    {val();}
 void val()
{  byte compteur=0;
   for(int f = 0;f<=3;f++)
      if (codefin[f] == code[f])
        compteur++;
    if (compteur==4)
      Serial.print("CODE BON");digitalWrite(ledv,HIGH);
      Serial.print("CODE MAUVAIS");
