Non-responsive Uno R3
Hi guys,
Today I noticed that my Uno didn't work as supposed, there is a basic sketch on it - reading some digital inputs and setting/resetting some outputs. When running I noticed that the outputs never got set. Connected the board to the computer (Win7) and tried to do some troubleshooting but now I couldn't get the computer to connect to the board. The computer says "Unknown device connected to the computer", I've tried to uninstall the drivers and re-install them but when the installation finishes I get "The software for this device was installed but may not work correctly. This device cannot start. (code 10)".
The "ON"-led is on, the voltages seem okay. I read somewhere that when you do a reset, the "L"-led is supposed to flash, it doesn't. The board has been connected to 12-13V supply, which is a bit higher than recommended but still okay I guess (limits between 6 and 20V).
Is there any way to check any signs of life on the board? I do also have a Mega2560, is there any way to use that one to check the functionality?
regards Anton
You could check to see if the Atmega328 or the Atmega16u2 are talking. First, get Nick Gammon's board programmer: http://www.gammon.com.au/forum/?id=11635
Put it in your sketch folder and open the sketch up. Go down to where the constants are defined and change:
const byte RESET = 53
const byte SCK = 52
Then Save as ABP_Mega or something else. Upload to the Mega. Of course, after upload, disconnect power.
Hook up Wires:
MEGA / UNO 5V - 5V GND - GND D50 - D12 D51 - D11 D52 - D13 D53 - RESET
Plug in the Mega and open the serial window @115200 baud.
You should get output of the Atmega328 and all the fuses. If that works, you will need to check the 16u2 from the ICSP header by the USB port (You could have done this as well for the Atmega328). The pins are as such
Pin1 / Pin2 (Pin 1 is closest to the white dot or "1") MISO - 5V SCK - MOSI RST - GND
or
D50 - 5V D52 - D51 D53 - GND
Unfortunately, unlike the Atmega328 UNO bootloader included in the sketch, the 16u2 firmware is not included. But, you can use your Mega as an Arduino programmer in avrdude and try to upload the firmware that comes with the Arduino IDE.
Great instructions, thanks!
It seems that the 328 is dead, I only get
"Atmega chip programmer Written by Nick Gammon"
on the serial display. I've ordered a new chip which I will try to get running instead.
Thanks again.
