Non-SMD FTDI IC
Is there a non-smd ftdi ic on the market?
I want to build an arduino using non-smd components, but would like to build it using usb.
If not, is there a board with only the FTDI as smd, and the rest as normal componentes?
thanks
FTDI chips are all SMT, so no luck there, but you do have some options.
If you want to roll your own circuit board, look at the FTDI chip-in-a-cable that the RBB uses. I like the looks of it, but haven't managed to acquire one yet.
Sparkfun and others make a breakout board that has the SMT part on a little board with through-holes. The lilypad arduino variant uses something like this.
If you happen to be seriously into rocketry, you may have one lying around: the MiniAlt family of altimeters use an FTDI breakout board as a computer interface.
NKC electronics has a kit with the SMT parts already soldered.
NKC and Fundamental Logic both offer RS232 variants that you can use with a standard USB/RS232 adapter (of course, you'll have to apply power to the board when going that route).
There are probably other solutions; these are what I can think of off the top of my head.
-j
There is another member of the forum, spiffed I think, who sells a Freeduino on eBay that has the SMD part soldered, the rest you can solder and it fits onto proto-board.
John
FWIW, I bought an iDuino from spiffed with the SMD FTDI chip soldered and the rest as a kit. I found it to be an excellent product and spiffed is a wonderful person to deal with.
