In my project, I want to calculate the lifespan of a lamp.
The lamp is turned ON whenever a sensor value is HIGH, the timer starts and runs until the lamp is turned OFF.
When the lamp is turned ON again the timer should continue from the previous value.
Also when the microcontroller is restarted it should recover previous timer value.
Should I go for an EEPROM or SD card for non-volatile memory?
Code I tried :
#include <EEPROM.h>
int addr = 0;
int POT = A0;
int PotVal = 0;
unsigned long previousMillis = 0;
const long interval = 1000;
unsigned long life = 0;
boolean eepromFlag = false;
pinMode(13, OUTPUT);
unsigned long EEPROMvalue = EEPROM.read(0);
PotVal = analogRead(POT);
if (PotVal >= 600) {
digitalWrite(13, HIGH);
if (currentMillis - previousMillis >= interval) {
if(eepromFlag == false){ // To Add previous saved value only once
life = life+EEPROMvalue;
eepromFlag = true;
life++;
Serial.print("Life : ");
Serial.println(life);
EEPROM.write(0, life);
else {
digitalWrite(13, LOW);
Can it be done using EEPROM ?
Since EEPROM can be written only certain times, how often should I write to EEPROM
Should I use external EEPROM or builtin EEPROM of Atmega328p.
So unless you can reliably predict when the microcontroller is restarted, you need to be continuously saving the current timer value to non-volatile memory.
So perhaps work out how often you want to save the timer value to memory and then you will know how many writes you need depending on how long the lamp is expected to last.
Does sound to me that a real time clock that has battery backed up RAM is a better place to store the timer value.
for loop can detect if it executing for first time or not
The data is written to EEPROM only when the lamp is turned OFF, until that it will be written to a local variable, So the life of EEPROM can be extended
Issue : When the lamp is turned ON and if the power goes it won’t store data to EEPROM
EEPROM.get(0,EEPROMvalue);
eepromFlag = true;
life++;
startFlag = true;
else {
if(startFlag == true){
EEPROM.put(0, life);
Serial.print("[Life] Update to EEPROM : ");
startFlag = false;
