NonBlocking code
Hey, I have this code but been working on options to make it non-blocking for the second part of the if, and else. The code works but not properly, any advice?
#include <Servo.h>
//This first part is where the LDR variables are defined
const int ldrPin1 = A1;  // we define were the LDR is connected in the Arduino Board
const int ldrPin2 = A2;
const int ldrPin3 = A3;
//This second part is where the pressure variables are defined
int AnalogPin = 0;  // This is the pressure sensor in the analog pin 0
int LEDpin = 6;     // This is where the LEDs of the fade are connected, in pin 6
Servo servo;
int reading;
int pression;
int fadeValue = 0;
unsigned long lastT;
bool anada = false;
bool timerOn = false;
//In the void setup, we declare the variables for both sensors
  Serial.begin(9600);  //We set a quote to see the status in the serial monitor
  pinMode(LEDpin, OUTPUT);  //We will define the LEDpin as an output
  servo.attach(9);  //The servo is attached in the pin 9
  servo.write(0);   //The servo starts at this value
  lastT = millis();
  //In this part we will define the Part of the LDR SENSOR LOOP
  int ldrStatus1 = analogRead(ldrPin1);
  int ldrStatus2 = analogRead(ldrPin2);
  int ldrStatus3 = analogRead(ldrPin3);
  int LEDStatus = analogRead(LEDpin);
  int servoStatus = analogRead(servo.attach(9));
  if (ldrStatus1 <= 400 || ldrStatus2 <= 400 || ldrStatus3 <= 400) {
    if (timerOn == false) {
      lastT = millis();
      timerOn = true;
      anada = true;
    if (millis() - lastT < 10000) {
      if (anada == true) {
        analogWrite(LEDpin, fadeValue);
        fadeValue += 2;
        if (fadeValue >= 255) {
          anada = false;
        fadeValue -= 2;
        if (fadeValue < 0) {
          anada = true;
      timerOn = false;
    analogWrite(LEDpin, 0);
  if (analogRead(A0) <= 20)
    servo.write(0);
  else {
    // servo turns from 0 to 180, waits one second
    servo.write(180);
    // servo turns from 180 to 90, waits one second
    servo.write(90);
    // servo turns from 90 to 0, waits one second
    servo.write(0);
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
#include <Servo.h>
Servo servo;
int reading;
int pression;
int fadeValue = 0;
bool anada = false;
  lastT = millis();
      lastT = millis();
      timerOn = true;
      anada = true;
        fadeValue += 2;
          anada = false;
        fadeValue -= 2;
          anada = true;
      timerOn = false;
    servo.write(0);
  else {
    servo.write(180);
    servo.write(90);
    servo.write(0);
something like this, not tested.
#include <Servo.h>
Servo servo;
int reading;
int pression;
int fadeValue = 0;
bool anada = false;
  lastT = millis();
unsigned long servoDelayTime = 1000;
unsigned long servoPastTime = millis();
int selectCounter = 0;
bool DoServoThing = false;
bool TickTock = True;
      lastT = millis();
      timerOn = true;
      anada = true;
        fadeValue += 2;
          anada = false;
        fadeValue -= 2;
          anada = true;
      timerOn = false;
  if ( (analogRead(A0) <= 20) && (DoServoThing == false) )
    servo.write(0);
    if ( TickTock )
      TickTock = false;
      DoServoThing = true;
      selectCounter = 0;
  if ( DoServoThing )
    switch ( selectCounter )
      case 0:
        servo.write(180);
        if ( (millis() - servoPastTime) >= servoDelayTime )
          selectCounter = 1;
      case 1:
        servo.write(90);
          selectCounter = 2;
        break;// servo turns from 90 to 0, waits one second
      case 2:
        servo.write(0);
          selectCounter = 0;
          TickTock = true;
      default:
        selectCounter = 0;
        TickTock = true;
You may need to troubleshoot or adjust to suit your requirements.
consider
#include <Servo.h>
Servo servo;
int fadeValue = 0;
int fadeDir   = 2;
char s [80];
unsigned long msecLst;
byte servoPos [] = { 180, 90, 0 };
byte servoIdx;
void
doServo (void)
    int anlg = analogRead (A0);
    if (anlg < 20) {
        unsigned long msec = millis ();
        if ( (msec - msecLst) > 1000)  {
            msecLst = msec;
            sprintf (s, "%s: servo pos %d", __func__, servoPos [servoIdx]);
            Serial.println (s);
            servo.write (servoPos [servoIdx]);
            servoIdx++;
            if (sizeof(servoPos) <= servoIdx)
                servoIdx = 0;
        servo.write(0);
 // int LEDStatus   = analogRead(LEDpin);
        fadeValue += fadeDir;
        if (0 >= fadeValue || 255 <= fadeValue)
            fadeDir = -fadeDir;
        Serial.println (fadeValue);
    doServo ();
You can't do an analogRead() from a digital pin. Not even a PWM output pin. I think you may mean int LEDStatus = digitalRead(LEDpin);
  1. You already attached Pin 9 to the servo.
  2. The value returned by servo.attach() is not an analog input pin.
    I don't know what you mean to put here. Maybe read back the last position sent to the servo? That's int servoStatus = servo.read();
