noob at C code, help with 6 inputs and 6 outputs
hi, new to figuring this code stuff out
not sure if this is in the correct forum
i can "see" what is happening and can adjust info like parameters but dont know how to assemble it all
my project is a 6 speed auto transmission with 6 solenoid control
i got an uno (unfortunately china copy it looks like) that i want to input 6 micro switchs (5V) for the gear selection
output will be on/off to a mosfets on a board
6 total again
the out puts will have certain pairing of solenoids for gear selection
i think i am heading down the right road with my copy and pasting of some C code pieces
i dont know how to link the input pin to a combo of output pins
i need these inputs to activate these outputs
sensorpin A0 = solpin 3 and 9
sensorpin A1 = solpin 3 and 6
sensorpin A2 = solpin 3 and 5
sensorpin A3 = solpin 3 and 9 and 10
sensorpin A4 = solpin 5 and 9 and 10
sensorpin A5 = solpin 6 and 9 and 10
not sure if i need to scrap my start text file and start another
i am pretty sure there is several ways to achieve this function but i have no real experience so i am open to any help and idea on the simple path on this
thanks matt
6 speed code.txt (586 Bytes)
well i have learned a lot in a day. lol
i like the "button" command or whatever you call it for the input
the digitalwrite would be good 5V into my mosfet board
check it out....
#include <Button.h>
Button button1 = Button(2);  //1st gear
Button button2 = Button(3);
Button button3 = Button(4);
Button button4 = Button(5);
Button button5 = Button(6);
Button button6 = Button(7);  //6th gear
void setup(){
 pinMode(8,OUTPUT);   //solenoid 1
 pinMode(9,OUTPUT);
 pinMode(10,OUTPUT);
 pinMode(11,OUTPUT);
 pinMode(12,OUTPUT);   //solenoid 5
void loop(){			//not sure if this is latching/holding on even after the button is released?  i found a thing "uniquePress" inplace of "isPressed"
 if(button1.isPressed()){
     digitalWrite(8,HIGH);
     digitalWrite(11,HIGH);
 if(button2.isPressed()){
       digitalWrite(10,HIGH);
 if(button3.isPressed()){
     digitalWrite(9,HIGH);
 if(button4.isPressed()){
       digitalWrite(12,HIGH);
 if(button5.isPressed()){
 if(button6.isPressed()){
 else{
     digitalWrite(11,HIGH);     //this would be park/reverse
It is a good idea to make variable names meaningful so instead of :-
Why not use:-
Button gear1 = Button(2);  //1st gear
Button gear2 = Button(3);
Button gear3 = Button(4);
Button gear4 = Button(5);
Button gear5 = Button(6);
Button gear6 = Button(7);  //6th gear
So you would now use code like this:
if(gear1.isPressed()){
Yes it is. When the button is being pressed the code in the if statement gets repeatedly run setting your two outputs high, which is fine. When you release it that code is no longer run and in the absence of anything else being pressed nothing will change. However when you press another button the two previous outputs will stay high and two new ones will go high. So instead of just setting the outputs high in the if statements you must also set the others low.
like this:-
     digitalWrite(9,LOW);
     digitalWrite(10,LOW);
     digitalWrite(12,LOW);
It is not. Much better in Programming or Project Guide
outstanding!
that all makes sense
thanks for the reply
i will update the code and post in the other forum for future help
