Noob for: Arduino DUE --- MPU-9150 --- MPU9150Lib
Greetings
I going to explain how to work the Arduino Due with MPU-9150 (9 Degrees of Freedom - MPU-9150 Breakout) from Sparkfun and MPU9150Lib from Pansenti.
The Library:
You can download the Library from: https://github.com/Pansenti/MPU9150Lib
To install the library, please follow the tutorial http://arduino.cc/en/Guide/Libraries
I use the manual installation. Inside the zip file, there a directory called “libraries”, use it!!
Wiring:
We only need 4 pin conection
Arduino Due MPU-9150
3.3V VCC
GND GND
SDA (pin 20) SDA
SCL (pin 21) SCL
The Sketch:
The final step is run the example sketch from the library with Due support.
From the zip file, there a special sketck with Due support, you can find this in directory called “Due9150”
The Output:
Note***
Some time we can receive a “Error Message” from the console, to fix the problem, unplug the Arduino (turn off) and conect again (turn on).
For more details, please read the documentation.
:wink: enjoy it!!!
Thanks for all, but I received some error in the compiling: "In file included from ...\Arduino\libraries\DueFlash/flash_efc.h:48, from ...\Arduino\libraries\DueFlash/DueFlash.h:29, from Due9150.ino:5: ...\Arduino\libraries\DueFlash/efc.h:116: error: 'Efc' was not declared in this scope ...\Arduino\libraries\DueFlash/efc.h:116: error: 'p_efc' was not declared in this scope ....\Arduino\libraries\DueFlash/efc.h:116: error: expected primary-expression before 'ul_access_mode' ....\Arduino\libraries\DueFlash/efc.h:116: error: expected primary-expression before 'ul_fws'" and on, and on, and on... How can I fix the problems? so much thanks. :)
Hello;
I am thinking about to buy MPU6050. Can I use the same code of 9050 for my 6050?
These libraries are gone :( Can anyone send them to me? info at 3dsolutions dot ca
Thanks in advance :)
https://github.com/zarthcode/MPU9150Lib
The old Pansenti libraries are available again at https://github.com/richards-tech/MPU9150Lib and https://github.com/richards-tech/linux-mpu9150. The repos had to be reorganized - sorry about that!
