I have been trying several methods to make a new menu for configuring the alarm. I tried using the onebutton library to no avail, likely because i also need my modifier button to change the current time when it is held down, hence i had kept the original code which did not use the onebutton library. I also tried using if((digital blah)&&(digitalblah)&&(digitalblah)&&(digitalblah) to activate the second menu but it did not work. I also tried doing the same but by putting it all around my original button code. I tried also having the day up and seconds down buttons (the two centre buttons) activate the menu switch code but this did not work either.
It would be good if someone could look at my menu switch code itself as i am not too confident on how good it might be. I have been testing by using the Buzz(); function as it lets me know if the code went through but otherwise I am not using an LED.
Here is my code:
Code: [Select]
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include "RTClib.h"
#include "OneButton.h"
#include <OneButton.h>
#include <LiquidCrystal.h>
#include <Servo.h>
RTC_DS1307 rtc;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
//RTC clock - Matthew Lim
//references
//*OLD* library info https://github.com/davidhbrown/RealTimeClockDS1307/blob/master/RealTimeClockDS1307.h ***ditched this library as it was missing features moved to RTCLIB
//RTCLIB library info https://github.com/adafruit/RTClib/blob/master/RTClib.h
//bare source 1: https://www.instructables.com/Arduino-Real-Time-Clock-DS1307/
//interesting idea to move to different library: https://arduino.stackexchange.com/questions/3354/why-is-my-real-time-clock-getting-the-wrong-time-from-my-pc
//https://www.arduino.cc/en/Reference/LiquidCrystal LCD library
//realtime updating rtc time https://forum.arduino.cc/index.php?topic=555628.0
// concept of adding double action buttons https://forum.arduino.cc/index.php?topic=512477.0
//buttons
int PM=6; //button modifier (using pin 6) - will try to make the other buttons change the days and the seconds when held down.
//OneButton onebuttonmodifier(6, true);
int P1=7; //button + hours (using pin 7)
int P2=8; //button - hours (using pin 8)
int P3=9; //button + minutes (using pin 9)
int P4=10; //button - minutes (using pin 10)
//servos
Servo hours; // hours is using pin 1
Servo minutes; // minutes is using pin 0
int hoursdegree = 0;
int minutesdegree = 0;
//buzzer
const int buzzer = 13;
//alarm stuff
bool mondayalarm = false;
bool tuesdayalarm = false;
bool wednesdayalarm = false;
bool thursdayalarm = false;
bool fridayalarm = false;
bool saturdayalarm = false;
bool sundayalarm = false;
int alarmhour = -1;
int alarmminute = -1;
int alarmsecond = -1;
//display
int lcddisplay = 1;
//1 would just be the regular time display
//2 would be the alarm display
void setup () {
Serial.begin(57600);
lcd.begin(16,2);
pinMode(A3, OUTPUT);
digitalWrite(A3, HIGH);
pinMode(A2, OUTPUT);
digitalWrite(A2, LOW);
pinMode(PM, INPUT);
pinMode(P1, INPUT); //allows program to recognise that we are using buttons
pinMode(P2, INPUT);
pinMode(P3, INPUT);
pinMode(P4, INPUT);
minutes.attach(A0);
hours.attach(A1);
pinMode(buzzer, OUTPUT);
// onebuttonmodifier.attachDoubleClick(modifierdoubleclick);
#ifndef ESP8266
while (!Serial); // wait for serial port to connect. Needed for native USB
#endif
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
Serial.flush();
abort();
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running, let's set the time!");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
void loop () {
DateTime now = rtc.now();
if (lcddisplay ==1)
lcdPrintdisplay1;
if (lcddisplay ==2)
lcdPrintdisplay2;
alarmAdjustMode();
timeAdjustButtons();
lcdPrintdisplay1();
clockfaceHands();
if ((now.hour() == alarmhour) && (now.minute() == alarmminute)){
Buzz();
//onebuttonmodifier.tick();
void timeAdjustButtons(){
if((digitalRead(P1)==HIGH)&&(digitalRead(PM)==HIGH))
uint32_t deltaT = 86400; // Move time ahead one day (maybe)
rtc.adjust(rtc.now() + TimeSpan(deltaT));
else{
if(digitalRead(P1)==HIGH)
uint32_t deltaT = 3600; // Move time ahead one hour
if((digitalRead(P2)==HIGH)&&(digitalRead(PM)==HIGH))
uint32_t deltaT = -86400; // Move time back one day (maybe)
else{
if(digitalRead(P2)==HIGH)
uint32_t deltaT = -3600; // Move time back one hour
if((digitalRead(P3)==HIGH)&&(digitalRead(PM)==HIGH))
uint32_t deltaT = 1; // Move time ahead one second
else{
if(digitalRead(P3)==HIGH)
uint32_t deltaT = 60; // Move time ahead one minute
if((digitalRead(P4)==HIGH)&&(digitalRead(PM)==HIGH))
uint32_t deltaT = -1; // Move time back one second
else{
if(digitalRead(P4)==HIGH)
uint32_t deltaT = -60; // Move time back one hour
void clockfaceHands(){
hoursdegree = (180-(now.hour()*7.5));
minutesdegree = (180-(now.minute()*3));
minutes.write(minutesdegree);
hours.write(hoursdegree); // tell servo to go to position in variable
void Buzz() {
tone(buzzer, 1000); // Send 1KHz sound signal...
delay(500); // ...for 1 sec
noTone(buzzer); // Stop sound...
delay(500); // ...for 1sec
//void modifierdoubleclick(){
//if (lcddisplay ==3){
// int lcddisplay = 1;
// else
// lcddisplay ++;
//Buzz();
void lcdPrintdisplay1(){
lcd.print(now.hour(), DEC);
lcd.print(":");
lcd.print(now.minute(), DEC);
lcd.print(":");
lcd.print(now.second(), DEC);
lcd.setCursor(0, 1);
lcd.print(now.day(), DEC);
lcd.print(":");
lcd.print(now.month(), DEC);
lcd.print(":");
lcd.print(now.year(), DEC);
delay(250);
lcd.clear();
lcd.setCursor(0, 0);
void lcdPrintdisplay2(){
lcd.print("Set Hrs and Mns");
lcd.print(alarmhour, DEC); //lcd.print(alarmhour);
lcd.print(":");
lcd.print(alarmminute, DEC); //lcd.print(alarmminute);
alarmhour++;
alarmhour-1;
alarmminute++;
alarmminute-1;
lcd.clear();
void lcdPrintdisplay3() {
lcd.setCursor(0,0);
lcd.print("Mon");
lcd.print(":");
lcd.print("");
void alarmAdjustMode() {
//if((digitalRead(P2)==HIGH)&&(digitalRead(P3)==HIGH))
//else
//lcddisplay +1;
// Buzz();
Here are some clips of the clock, they might help you see what I am trying to achieve:
Any help with my code would be greatly appreciated. Thanks!
