It works. Thank you.
Hello Erdin,
The MPU9150 works fine with libraries from Februar 2013.
I get the following error message when I use the current libraries.
Compiling 'Quad102' for 'Arduino Mega 2560 or Mega ADK'
Quad102.ino : In file included from
MPU6050_9Axis_MotionApps41.h : : In member function 'uint8_t MPU6050::dmpInitialize()':
MPU6050_9Axis_MotionApps41.h : 'setXGyroOffsetUser' was not declared in this scope
MPU6050_9Axis_MotionApps41.h : 'setYGyroOffsetUser' was not declared in this scope
MPU6050_9Axis_MotionApps41.h : 'setZGyroOffsetUser' was not declared in this scope
Error compiling
Your post dated "March 13, 2013, 07:08:29 pm".
I changed only the "MPU6050 6 Axis MotionApps 20.h" in "MPU6050 9Axis MotionApps4.h1" from the MPU6050 example. Isn´t that right?
Thank you for your patience.
Willi
No that is not right.
It might work if you carefully change the #include in every *.cpp file. But the library is complex enough, don't try to make things more difficult.
The compiler complains that it can't find some functions. It needs the *.h file for that.
Hey,
I don´t understand.
I use MPU 9150 breakout with level shifter. No file is changed.
I copied all libraries(_stup - TCA6424A) with changelog "2012-06-21" into the Arduino libraries folder.
I changed this part in the example "MPU6050_DMP6.ino".
#include "I2Cdev.h"
#include <MPU6050_9Axis_MotionApps41.h> <----------
#include <helper_3dmath.h>
#include "Wire.h"
//#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h"
Compiling OK.
Now I copied the newest Lib-Versions (changelog 2013-05-08) into the Arduino libraries folder.
#include "I2Cdev.h"
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
Compiling 'MPU6050_DMP6' for 'Arduino Nano w/ ATmega328'
MPU6050_DMP6.ino : In file included from
Error compiling
Please excuse me, but I do not understand.
Willi
I don't know what is wrong. Perhaps you have only half the new library, or the library itself is wrong. That include file is updated a few days ago and I read : "changelog : ongoing debug release".
Perhaps you have to wait a few days and update everything.
Cood idea. Thanks.
Willi
i have a big problem with mpu 9150 i tried more then one example about mpu 9150 and still having the same problem witch is >>>> calculating yaw , pitch , roll from the values ax , ay, az , gx , gy , gz , mx , my , mz .
