Please help me with these bits of code, I am unable to tell the problems
#include <Wire.h>
#include <math.h>
int sensorpin = A0;
pinMode(12, OUTPUT); // sets the LED at pin 12
double c = 4*(sq(PI)); // declaring the constant 4 pi^2
double L = 48;
Wire.begin(2); // initializes the i2c bus
int val = analogRead(sensorpin);
digitalWrite(12, HIGH);
if(val > 200)
do
double T = 2*(micros()/1000);
while (val < 200);
int T2 = (int) T * (int) T;
double g = double c* double L/T2;
delay(25);
byte Tp = (byte) T2;
byte gr = (byte) g;
byte test[2] = {
Tp, gr };
Wire.write(test, 2);
and the other
#include <LiquidCrystal.h> // The LCD library
#include <Wire.h> // The i2c bus library
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //Pins used
lcd.begin(16, 2);
Wire.begin(1);
Wire.requestFrom(2, 96);
recieveEvent();
byte thisArray[2];
lcd.print("The period =");
lcd.print(thisArray[1]);
lcd.setCursor(0, 1);
lcd.print("The value of g =");
lcd.print(thisArray[2]);
void recieveEvent()
while(Wire.available() >0)
for(int p = 0; p<2; p++)
byte thisArray[p] = Wire.read();
I'm trying to use one uno with an IR light gate that times the period of a pendulum swinging and then sending the info to the other (second bit of code) to display on a 16x2 LCD. Any help?
Slave.ino: In function 'void loop()':
Slave:34: error: 'T' was not declared in this scope
Slave:35: error: expected primary-expression before 'double'
Slave:35: error: expected ',' or ';' before 'double'
and in the second
master.ino: In function 'void recieveEvent()':
master:40: error: variable-sized object 'thisArray' may not be initialized
You only have to declare a variable once. Preferably at the beginning of your program, unless it's local to a function (which, by the way, is not a bad thing). You already did it with some variables but they are declared inside setup().
Once a variable is declared, like:
int x = 77;
you should reference it without a declarator from that point on, like:
x = 66;
The compiler remembers what data type you asked for.
Slave:35: error: 'c' was not declared in this scope
Slave:35: error: 'L' was not declared in this scope
Declare a variable only once.
Declare it in the function that is used.
Declare it before you use it.
If it is used in multiple functions, declare it outside a function (outside setup() or loop()).
Sorry I just fixed the declaration problem;
would you be able to help with this bit of code ?
Ok so, this arduino receives data sent from the other one and
dosen't do anything more than display it. We needed two arduinos
for the number of pins the lcd takes up
lcd.begin(16, 2);
Wire.begin(1);
recieveEvent();
byte thisArray[2];
void recieveEvent()
as it gives this error:
