Noob - How to interrupt a loop cleanly
I was playing with the push button tutorial from a kit I got but wanted to play with some other functions. One thing I wanted to play with is pushing two buttons at the same time would start blinking. I got it to do so but it seems like a hack since the loop time is small enough to read the push button changes but if I wanted to change the duration of the blinking, it wouldn't suffice. I know there are interrupt functions but don't know how to use it. How would you suggesting doing this?
Here's what I ended up with for code. The WHILE loop at the end is what I wrote to enable the blinking.
const int buttonPin1 = 2;     // the number of the pushbutton pin
const int buttonPin2 = 3;
const int ledPin =  13;      // the number of the LED pin
int buttonState1 = 0;         // variable for reading the pushbutton status
int buttonState2 = 0;
int lastState1 = 1;
int lastState2 = 1;
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState1 = digitalRead(buttonPin1);
  buttonState2 = digitalRead(buttonPin2);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState1 == LOW && buttonState2 == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, LOW);
    lastState1 = 0;
    lastState2 = 1;
  else if (buttonState2 == LOW && buttonState1 == HIGH) {
    // turn LED off:
    digitalWrite(ledPin, HIGH);
    lastState1 = 1;
    lastState2 = 0;
   else if (buttonState1 == LOW && buttonState2 == LOW) {
    lastState1 = 0;
    lastState2 = 0;
   while (lastState1 == 0 && lastState2 == 0 && digitalRead(buttonPin1) == HIGH && digitalRead(buttonPin2)==HIGH){
    digitalReady(buttonPin1);
Check out the "blink without delay" example and re-code your program based on that.
Thanks for the pointer!
