Noob needs help controlling 7 volt drill
I have exactly zero experience with arduino but I am completely intrigued by it and want to jump in.
To start, I need to learn how to use arduino to power a 7 volt drill for six seconds, then reverse polarity and run it for another six seconds, then turn off.
What do I need to do in terms of board and code?
Thanks
You can not directly do that with Arduino.
Arduino does not have 7 volts available for controlling the motor in the drill, and most important Arduino can not supply the current to drive the drill.
But with an external powersupply to power the drill and a thing called an H bridge (basically an IC) you can control the drill from Arduino.
Search the forum for H bridge or google arduino + H bridge.
The last piece of information you need to find out is what is the worst case load current the drill will draw under real operating conditions?
H-drives are sold by the max voltage and current capacity they can work with. So you need a digital multimeter set up to read DC amps and then use your drill with the mechanical load you need turning and measure the current. Whatever it is the H-drive you select should have a rating of about double that for a good safety and heating margin.
Lefty
Or you can use old fashioned relays, see:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
and
http://www.thebox.myzen.co.uk/Workshop/Motors_2.html
This assumes that the motor won't exceed the max current rating of the meter (which for most small meters is around 10 amps); if it does, then "poof" goes the meter (well, the fuse inside, likely).
If you think the motor will pull more amps than your meter (or you know it does because your meter now no longer measures current!), then measuring the voltage drop across an appropriate sized shunt (essentially a very small value, but high wattage resistor - there do exist purpose-built shunts, but a 10-15 watt 1-ohm resistor would work OK - you can also build a shunt using solid copper wire of an appropriate gauge; knowing the gauge you can find out the resistance per foot and thickness, then build a shunt based on that info - plenty of places and videos on the net available - just look up "homemade shunt") would be the next step.
I have an external power supply to feed the drill, I just want to know what hardware and code I need to run the system.
Is there some sort of virtual arduino emulator that I can download to get some hands on experience writing code on the computer?
Consider the arduino your emulator and use leds as the drill until you get the code part right.
You say you are a noob. Is that just with the arduino? Do you have experience driving high current devices with relays or MOSFETS?
Kevin
