So this is the main sketch where I check whether either one of the 5 buttons is pressed. Depending on the combination then it either calls an effect function right away or changes the pattern switch case. It is more or less repeating everything for each pad so I only left out 2 examples per category just to get an idea. I haven't included the sketches for the effects, hope that makes it clearer.
#define LED0_PIN 2
#define LED1_PIN 3
#define LED2_PIN 5
#define LED3_PIN 6
#define LED4_PIN 7
#define CLOCK_PIN 13
#define BUTTON_NUM 5
//#define STRIPS_NUM 2
// button 0 -> RED
// button 1 -> GREEN
// button 2 -> BLUE
// button 3 -> YELLOW
// button 4 -> WHITE
int buttonPIN[] = {8, 9, 11, 12, 10}; // also change the number of elements in #define BUTTON_NUM
int reading[BUTTON_NUM];
static int lastReading[BUTTON_NUM];
unsigned long patternInterval = 20 ; // time between steps in the pattern
unsigned long lastUpdate = 0 ; // for millis() when last update occoured
unsigned long intervals [] = { 20, 20, 50, 100 } ; // speed for each pattern
int counter, counter1, counter2, counter3, counter4 = 0;
unsigned long buttonPress, buttonPress1, buttonPress2, buttonPress3, buttonPress4;
unsigned long startButton, startButton1, startButton2, startButton3, startButton4;
unsigned long woohoo;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(180, LED0_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(180, LED1_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip2 = Adafruit_NeoPixel(180, LED2_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip3 = Adafruit_NeoPixel(180, LED3_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip4 = Adafruit_NeoPixel(180, LED4_PIN, NEO_GRB + NEO_KHZ800);
// sanity check delay - allows reprogramming if accidently blowing power w/leds
//delay(2000);
#ifdef _AVR_ATtiny85_
// This is for Trinket 5V 16MHz
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
// End of trinket special code
#endif
wipe();
wipe1();
wipe2();
wipe3();
wipe4();
for (int i = 0; i < BUTTON_NUM; i++) {
pinMode(buttonPIN[i], INPUT_PULLUP);
static int pattern, pattern1, pattern2, pattern3, pattern4 = 0;
reading[i] = digitalRead(buttonPIN[i]);
printReadings(); //prints all readings
// --------------------------------------------------------- 3 BUTTONS ---------------------------------------------
if (reading[2] == HIGH && lastReading[2] == LOW && reading[3] == HIGH && lastReading[3] == LOW && reading[4] == HIGH && lastReading [4] == LOW ) {
threeColorsA();
// ---------------------------------------------- CHECK COMBINATIONS OF TWO BUTTONS ------------------------------------
// Pad 0 and 1
if (reading[0] == HIGH && reading[1] == HIGH && reading[3] == LOW && reading[4] == LOW && reading[2] == LOW ) {
Serial.println("button [0] and [1] pressed");
// pattern = 4;
twoColors(strip.Color(random(180, 255), 0, random(10, 55)), strip.Color(0, random(180, 255), random(10, 65)));
twoColors1(strip1.Color(0, random(180, 255), random(10, 65)), strip1.Color(random(180, 255), 0, random(10, 55)));
// Pad 1 and 2
else if (reading[1] == HIGH && reading[2] == HIGH && reading[3] == LOW && reading[4] == LOW && reading[0] == LOW) {
Serial.println("button [1] and [2] pressed");
twoColors1(strip1.Color(0, random(180, 255), random(10, 65)), strip1.Color(0, random(10, 65), random(180, 255)));
twoColors2(strip2.Color(0, random(10, 65), random(180, 255)), strip2.Color(0, random(180, 255), random(10, 65)));
// -------------------------------------------- TWO PADS ACROSS --------------------------------------
// Pad 0 and 2 - red and blue
else if (reading[0] == HIGH && reading[2] == HIGH) {
Serial.println("button [0] and [2] pressed");
twoColorsZeroTwo(strip.Color(random(180, 255), 0, random(10, 55)), strip.Color(random(10, 55), 0, random(180, 255)));
twoColorsZeroTwo(strip2.Color(random(10, 55), 0, random(180, 255)), strip2.Color(random(180, 255), 0, random(10, 55)));
// Pad 0 and 3 - red and yellow
else if (reading[0] == HIGH && reading[3] == HIGH && reading[2] == LOW && reading[1] == LOW && reading[4] == LOW) {
Serial.println("button [0] and [3] pressed");
twoColorsZeroThree(strip.Color(random(180, 255), 0, random(10, 55)), strip.Color(random(140, 255), random(140, 255), 0));
twoColorsZeroThree( strip3.Color(random(140, 255), random(140, 255), 0), strip3.Color(random(180, 255), 0, random(10, 55)));
else singleButtonPress_check(); //check for buttons not pressed
void singleButtonPress_check() {
if (reading[0] == LOW) {
// wipe(); //=clear
blue();
strip.begin();
strip.setBrightness(250);
if (reading[1] == LOW) {
// wipe1(); //=clear
blue1();
strip1.begin();
strip1.setBrightness(250);
checkSingleButtonPress();
void printReadings() {
Serial.print("reading[0] = ");
Serial.print( reading[0]);
Serial.print(" reading[1] = ");
Serial.print( reading[1]);
Serial.print(" lastRd[0] = ");
Serial.print( lastReading[0]);
Serial.print(" lastRd[1] = ");
Serial.println( lastReading[1]);
// --------------------------------------- STEPPING ON ONE PAD OR JUMPING ----------------------------------
// if activated 3 times in the span of some seconds = jumping
// --------------------------------------------------------- PAD0 ---------------------------------------------------------
if (lastReading[0] == LOW && reading[0] == HIGH && reading[1] == LOW && reading[2] == LOW && reading[3] == LOW && reading[4] == LOW ) {
static int lowTime = millis();
blue();
if (millis() - lowTime > 2000) {
wipe();
blue();
counter ++;
buttonPress = millis();
if (counter == 1) {
// pattern = 0;
startButton = millis();
Serial.println("START");
// jumping
if (counter >= 3 && buttonPress - startButton < counter * 200) {
Serial.println("wohooo");
pattern = 9;
if ( counter >= 3 && buttonPress - startButton > counter * 200 ) {
Serial.println("END");
counter = 0;
wipe();
blue();
//pattern = 0;
wipe(); // clear out the buffer
delay(50); // debounce delay
// --------------------------------------------------------- PAD1 ---------------------------------------------------------
if (lastReading[1] == LOW && reading[1] == HIGH && reading[2] == LOW && reading[0] == LOW && reading[3] == LOW && reading[4] == LOW ) {
blue1();
wipe1();
blue1();
counter1 ++;
buttonPress1 = millis();
// pattern1 = 0;
if (counter1 == 1) {
startButton1 = millis();
Serial.println("START1");
// jumping
if (counter1 >= 3 && buttonPress1 - startButton1 < 2000 + counter1 * 250) {
Serial.println("wohooo1");
pattern1 = 10;
if ((counter1 >= 3 && buttonPress1 - startButton1 > 2000 + counter1 * 250 ) ) { // || millis() - woohoo > 2000
Serial.println("END1");
counter1 = 0;
// pattern1 = 0;
wipe1(); // clear out the buffer
// stop flickering after some time (applies for all strips)
if ((pattern == 9 || pattern == 10 || pattern == 11 || pattern == 12 || pattern == 13) && millis() - buttonPress > 1000 ) {
Serial.println("georgei");
// pattern = 0;
counter = 0;
if ((pattern1 == 9 || pattern1 == 10 || pattern1 == 11 || pattern1 == 12 || pattern1 == 13) && millis() - buttonPress1 > 1000 ) {
// pattern1 = 0;
counter1 = 0;
lastReading[i] = reading[i]; // save for next time
if (lastReading[0] == HIGH || millis() - buttonPress > 50) updatePattern(pattern);
if (lastReading[1] == HIGH || millis() - buttonPress1 > 50) updatePattern1(pattern1);
