Sincere apologies for reposting this….but I though this got lost….would much appreciate help for all the kind people here…….
I have had good luck with fabricating the controller for my 4x4x4 bi-colored led cube with some really helpful inputs from here. While the actual cube is still to be made I wanted to give the code a thought. My set up is:
1.64 common cathode bi colored LEDs stacked in 4x4x4 form with layers sharing common cathodes and columns sharing anodes. So I have 4 ground pins and 32 anode pins (16x2)
2.I have daisy chained 4 74HC595s to be able to drive the anodes using discrete high side switches and 4 2N2222s driven straight from the Arduino for the layers
There is a fairly popular code that I found online and have used before for my single colored cube:
#include <avr/pgmspace.h> // allows use of PROGRAM to store patterns in flash
#define CUBESIZE 4
#define PLANESIZE CUBESIZE*CUBESIZE
#define PLANETIME 3333 // time each plane is displayed in us -> 100 Hz refresh
#define TIMECONST 20 // multiplies DisplayTime to get ms - why not =100?
// LED Pattern Table in PROGMEM - last column is display time in 100ms units
// TODO this could be a lot more compact but not with binary pattern representation
prog_uchar PROGMEM PatternTable[] = {
// blink on and off
B0001,B0000,B0000,B0000,B0001,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,B0000,10,
// this is a dummy element for end of table (duration=0) aka !!!DO NOT TOUCH!!!
B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, 0
** Defining pins in array makes it easier to rearrange how cube is wired
** Adjust numbers here until LEDs flash in order - L to R, T to B
** Note that analog inputs 0-5 are also digital outputs 14-19!
** Pin DigitalOut0 (serial RX) and AnalogIn5 are left open for future apps
int LEDPin[] = {
0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
int PlanePin[] = {
16, 17, 18, 19};
// initialization
int pin; // loop counter
// set up LED pins as output (active HIGH)
for (pin=0; pin<PLANESIZE; pin++) {
pinMode( LEDPin[pin], OUTPUT );
// set up plane pins as outputs (active LOW)
for (pin=0; pin<CUBESIZE; pin++) {
pinMode( PlanePin[pin], OUTPUT );
// display pattern in table until DisplayTime is zero (then repeat)
// declare variables
byte PatternBuf[PLANESIZE]; // saves current pattern from PatternTable
int PatternIdx;
byte DisplayTime; // time*100ms to display pattern
unsigned long EndTime;
int plane; // loop counter for cube refresh
int patbufidx; // indexes which byte from pattern buffer
int ledrow; // counts LEDs in refresh loop
int ledcol; // counts LEDs in refresh loop
int ledpin; // counts LEDs in refresh loop
// Initialize PatternIdx to beginning of pattern table
PatternIdx = 0;
// loop over entries in pattern table - while DisplayTime>0
do {
// read pattern from PROGMEM and save in array
memcpy_P( PatternBuf, PatternTable+PatternIdx, PLANESIZE );
PatternIdx += PLANESIZE;
// read DisplayTime from PROGMEM and increment index
DisplayTime = pgm_read_byte_near( PatternTable + PatternIdx++ );
// compute EndTime from current time (ms) and DisplayTime
EndTime = millis() + ((unsigned long) DisplayTime) * TIMECONST;
// loop while DisplayTime>0 and current time < EndTime
while ( millis() < EndTime ) {
patbufidx = 0; // reset index counter to beginning of buffer
// loop over planes
for (plane=0; plane<CUBESIZE; plane++) {
// turn previous plane off
if (plane==0) {
digitalWrite( PlanePin[CUBESIZE-1], HIGH );
else {
digitalWrite( PlanePin[plane-1], HIGH );
// load current plane pattern data into ports
ledpin = 0;
for (ledrow=0; ledrow<CUBESIZE; ledrow++) {
for (ledcol=0; ledcol<CUBESIZE; ledcol++) {
digitalWrite( LEDPin[ledpin++], PatternBuf[patbufidx] & (1 << ledcol) );
patbufidx++;
// turn current plane on
digitalWrite( PlanePin[plane], LOW );
// delay PLANETIME us
delayMicroseconds( PLANETIME );
} // for plane
} // while <EndTime
while (DisplayTime > 0); // read patterns until time=0 which signals end
While I broadly understand the code I have a few specific questions so that I can modify it to be able to work on my shift registered setup:
1.In the line memcpy_P( PatternBuf, PatternTable+PatternIdx, PLANESIZE ) is the entire bit string (all 16 4-bit values) copied into the PatternBuf array?
2.If yes, then can someone please explain to me how are these values being loaded individually onto the output ports?
3.If the answer to the previous question is digitalWrite( LEDPin[ledpin++], PatternBuf[patbufidx] & (1 << ledcol) ); then I would really be grateful if someone could explain this to me.
My idea is to be able to modify the code to use 4 32-bit values (each representing one layer) and load them on the shift registers using SPI similar to what the line of code in #3 is doing (if I understand correctly). However, I am not sure if this approach makes sense. I would really appreciate if someone could help me out and point me in the right direction.
Also if this approach is practical then can someone give me an example about how can I modify the part of the code that loads data individually using digitalWrite() to use the SPI.transfer()
