noob q
how do i make this work ??
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1251509480
cheers
skip
Just stick them in the same folder as your .pde sketch...
Mowcius
Thanks m8
But i am still having a hard time with it lol
Could somebody plz plz plz write me a small peace of code
useing the EasyDriver.h ???
just make the stepper move 1000 steps or so.
just so i can see how to use it.
as this has bin doing my head in for hours/days : :cry:
thanks guys
skip
Why don't you show us what your code looks like, then we can maybe poit you in the right direction?
what am i doing wrong guys ??
#include <easydriver.h>
int dir_pin = 3;
int step_pin = 12;
int (steps);
int (dirpin);
int (steppin);
Stepper stepper = Stepper(steps,dirpin,steppin);
 int val = 2000;
Stepper.step=(val);
delay (1000);
Stepper.step=(-val);
int (steps);
int (dirpin);
int (steppin);
You should not have round brackets in these declarations:
int steps;
int dirpin;
int steppin;
You will also need to write a "loop" function:
void loop ()
You must tell us a bit more about what you want to do in the main part of the sketch, and that code will replace the "..." above.
Also:-
Stepper.step=(val);
delay (1000);
should be:-
Stepper.step=(val);
delay (1000);
delay (1000);
Otherwise you go right round the loop with no delay.
Sorry guys, but y'all missed it:
int dir_pin = 3;
int step_pin = 12;
int (steps);
int (dirpin);
int (steppin);
You are calling your constructor method with un-initialized variables.
This should read something like this:
int dir_pin = 3;
int step_pin = 12;
int steps = ##  // put a number here. It will depend on your particular motor.
Stepper stepper = Stepper(steps, dir_pin, step_pin);
What you were doing is assigning a value to "dir_pin" and "step_pin", but then calling the constructor with "dirpin" and "steppin". These are different variable names which never had values assigned to them. Likewise, you never assigned a value to "steps" before the constructor.
