Hi Guys,
This my first ever project. Trying to make a reflexes game where you must hit a Piezo within a set time (1000 ms currently) after a light comes on. I then want the loop to start again after a random pause. I have assigned a RGB LED to correspond to certain actions.
The program works fine for one cycle when the arduino is reset, but after that first loop cycle, it no longer responds. I think this is because my millis() equation is off.
I’ve searched the forum and tried to educate myself on the millis command, but after 2 days I can’t see what I’m doing wrong. Could you please help out a noob who bought his first board 3 days ago?
THanks!
int redLedPin = 9; // RGB red LED pin 9
int greenLedPin = 10; // RGB green LED pin 10
int blueLedPin = 11; // RGB blue LED pin 11
int knock = 0; // Piezo sensor
unsigned long StartTime = millis();
pinMode (redLedPin, OUTPUT); //RGB LEN pins OUTPUTs
pinMode (greenLedPin, OUTPUT);
pinMode (blueLedPin, OUTPUT);
unsigned long CurrentTime = millis();
unsigned long ElapsedTime = CurrentTime - StartTime;
analogWrite(blueLedPin, 255); // RGB LED is blue
analogWrite(greenLedPin, 0);
analogWrite(redLedPin, 0);
knock = analogRead(0); // Piezo on analog pin 0
if ((knock > 10)&&(ElapsedTime < 1000)) // If Piezo value is greater than 10 and Elapsed time from start of blue light is less than 1000 milliseconds, then:
analogWrite(blueLedPin, 0); // RGB LED turns green for 500 milliseconds
analogWrite(greenLedPin, 255);
analogWrite(blueLedPin, 0); //RGB LED turns yellow for 500 milliseconds
analogWrite(greenLedPin, 100);
analogWrite(redLedPin, 255);
analogWrite(blueLedPin, 0); // RGB LED turns red for a random time of between 1 and 5 seconds
delay(random(1000, 5000));
