Another day, another question.
I'm looking to have a string, ranging in size from 7 to 15 characters (specifically, an IP address), passed into a function so I can confirm it's a valid IP address. I have been reading online and have seen that you can't directly pass a string into a function, just use an asterisk to point to an existing string (I think).
Here's the function:
int IPValidator(char * IPAddress)
// This will confirm the validity of a given IP address.
// It checks for octets and if the number is under 255.
// returns 1 if a problem, 0 if OK
// first, look for octets. Distinguished by a period.
// if we don't have three periods, bail.
// If we do, record location. We'll need it later.
 int FirstOctetLoc = IPAddress.indexOf('.');
 int SecondOctetLoc = IPAddress.indexOf('.', FirstOctetLoc+1);
 int ThirdOctetLoc = IPAddress.indexOf('.',SecondOctetLoc+1);
 if (FirstOctetLoc == -1 || SecondOctetLoc == -1 || ThirdOctetLoc == -1) {
  return 1;
 char IPAddressBuffer[IPAddress.length()];
 IPAddress.toCharArray(IPAddressBuffer,IPAddress.length());
// First Octet
 String FirstOctetString = IPAddress.substring(0,FirstOctetLoc);
 char FirstOctetChar[4];
 FirstOctetString.toCharArray(FirstOctetChar,4);
 int FirstOctet=atoi(FirstOctetChar);
// Second Octet
 String SecondOctetString = IPAddress.substring(FirstOctetLoc+1,SecondOctetLoc);
 char SecondOctetChar[4];
 SecondOctetString.toCharArray(SecondOctetChar,4);
 int SecondOctet=atoi(SecondOctetChar);
// Third Octet
 String ThirdOctetString = IPAddress.substring(SecondOctetLoc+1,ThirdOctetLoc);
 char ThirdOctetChar[4];
 ThirdOctetString.toCharArray(ThirdOctetChar,4);
 int ThirdOctet=atoi(ThirdOctetChar);
// Fourth Octet
 String FourthOctetString = IPAddress.substring(ThirdOctetLoc+1,IPAddress.length());
 char FourthOctetChar[4];
 FourthOctetString.toCharArray(FourthOctetChar,4);
 int FourthOctet=atoi(FourthOctetChar);
 if (FirstOctet > 255 || SecondOctet > 255 || ThirdOctet > 255 || FourthOctet > 255){
  return 1;
 else {
  return 0;
If I add this to my code, I get this error:
error: request for member 'length' in 'IPAddress', which is of non-class type 'char*'
What did I do wrong this time?
strings, lower case 's' are not the same as Strings upper case 'S'.
Mark
you are passing a pointer to a string (not a String which is an object) and so you cannot use String object methods like indexOf
holmes4:
Mark
I'm discovering that.
In this case, it is a String with a capital S.
HugoPT:
So, is it possible to parse a String in a function at all? If so, how can I do this?
Yes.
First, you need to pass a String (rather than a string) to the function, which needs to be designed to accept a String (rather than a string).
OK, passing a String instead of a string worked. At least, it passed compiling.
int IPValidator(String IPAddress)
  return 1;
// First Octet
// Second Octet
// Third Octet
// Fourth Octet
  return 1;
 else {
  return 0;
String has a toInt() method that is faster than copying the char array and then calling atoi() on the char array.
