Hi !!
I managed to send sensors values to my MQTT server using JSON & Serial connection.
I bought a W5100 shield and tried to adapt the code to send it using PubSubClient library and it fails …
I’m sure it’s a beginner’s mistake but can’t figure it out so far …
Help appreciated
Exact error message is :
ccWmM6Bs.ltrans0.ltrans.o: In function `PubSubClient::PubSubClient(IPAddress, unsigned int, void ()(char, unsigned char*, unsigned int), Client&) [clone .constprop.42]’:
:(.text.startup+0x66): undefined reference to `callback(char*, unsigned char*, unsigned int)’
:(.text.startup+0x68): undefined reference to `callback(char*, unsigned char*, unsigned int)’
collect2.exe: error: ld returned 1 exit status
Here’s the code :
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
byte mac[] = { 0xED, 0xDE, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress ip(192, 168, 50, 211);
IPAddress server(192, 168, 50, 210);
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
EthernetClient ethClient;
PubSubClient client(server, 1883, callback, ethClient);
//mq-2 capteur de fumées
int mq2_1 = A4;
int mq2Thres = 400;
#include <EmonLib.h>
EnergyMonitor emon1;
int tension = 230.0;
int pin_sct = 2;
//YF-S201_1
volatile int flow_frequency_1; // Measures flow meter pulses
unsigned int l_min_1; // Calculated litres/hour
unsigned char flowmeter_1 = 2; // digital PIN 2
unsigned long currentTime;
unsigned long cloopTime;
//LCD
//#include <Wire.h>
//#include <LiquidCrystal_I2C.h>
//LiquidCrystal_I2C lcd(0x27,15, 2);
//DHT22
#include "dht.h"
#define dht_apin_1 A0 // Analog Pin sensor is connected to
dht DHT_1;
//PIR
int pirPin_1 = 52; //the digital pin connected to the PIR sensor's output
int pir_1; //valeur (0/1) renvoyée à Node Red
//fonction YF-S201_1
void flow_1 () // Interrupt function
flow_frequency_1++;
//Demarrage du port série
//Serial.begin(115200);
//LCD
//lcd.init();
//lcd.backlight();
//MQ-2
pinMode(mq2_1, INPUT);
//PIR
pinMode(pirPin_1, INPUT);
digitalWrite(pirPin_1, LOW);
//YF-S201 (flow sensor)
pinMode(flowmeter_1, INPUT);
attachInterrupt(0, flow_1, RISING);
sei();
currentTime = millis();
cloopTime = currentTime;
//AS-103 capteur de courant
emon1.current(pin_sct,29);
void loop ()
Ethernet.begin(mac, ip);
if (client.connect("arduinoClient2")) {
// Every second, calculate and print litres/hour + récupère la valeur des sondes
if(currentTime >= (cloopTime + 1000))
cloopTime = currentTime; // Updates cloopTime
//YF-S201 : Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min. (Results in +/- 3% range)
l_min_1 = (flow_frequency_1 / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flow rate in L/hour
flow_frequency_1 = 0; // Reset Counter
//lecture DHT22
int readData = DHT_1.read22(dht_apin_1);
//variables DHT22
float t_1 = DHT_1.temperature;
float h_1 = DHT_1.humidity;
//photoresistance
int phR_1 = analogRead(A1);
//PIR
if(digitalRead(pirPin_1) == HIGH)
pir_1 = 1;
if(digitalRead(pirPin_1) == LOW)
pir_1 = 0;
double Irms = emon1.calcIrms(1480); //calcul du courant ?
//MQ-2
int mq2_1Value = analogRead(mq2_1);
if (mq2_1Value > mq2Thres)
client.publish("MQ-2_1",'1'); //fumée détectée !!
client.publish("MQ-2_1",'0'); //pas de fumée
client.publish("DHT_T_1",(char)t_1);
client.publish("DHT_H_1",(char)h_1);
client.publish("PIR_1",pir_1);
client.publish("phR_1",phR_1);
client.publish("YF_S201_1",l_min_1);
client.publish("AS_103_1",(char)Irms);
//sortie JSON série
//ouverture JSON
Serial.print("{");
//DHT22_1
Serial.print("\"DHT_T_1\":");
Serial.print(t_1);
Serial.print(",\"DHT_H_1\":");
Serial.print(h_1);
//PIR_1
Serial.print(",\"PIR_1\":");
Serial.print(pir_1);
//photo resistance
Serial.print(",\"phR_1\":");
Serial.print(phR_1);
Serial.print(",\"YF_S201_1\":");
Serial.print(l_min_1, DEC); //litres par minute
Serial.print(",\"AS_103_1\":");
Serial.print(Irms);
//fermeture JSON
Serial.println("}");
//affichage LCD
//lcd.setCursor(0, 0);
//lcd.print(t);
//lcd.setCursor(0, 1);
//lcd.print(h);
Thanks a lot !!
