Hi guys,
I've been looking at doing my second project, and seen this which i think is pretty cool Arduino + WiiChuck steered laser pointer - Maks Surguy's blog on Technology Innovation, IoT, Design and Code
Basically, i'm having difficulty compiling the code. But thats not what i want help with, i was wondering if anyone had the time to explain to bme, how the code is broken down, and what the commands re late to. Then with more knowledge i'd be able to go back in and alter the errors. I've spent time tryin to understand it, but am struggling to find understandable answers online.
Or if you have any useful links in which i can read and try understand deeper would be appreciated. Basics i can do, but maybe a bit in over my head on this
Many thanks
Marcus
system
April 10, 2015, 2:37pm
2
The code would be considerably shorter and therefore easier to understand if it used the Servo library.
Which bits, specifically, don't you understand?
#include <Wire.h>
#include <string.h>
#include <stdio.h>
uint8_t outbuf[6];
int cnt = 0;
int ledPin = 13;
int laserPin = 12;
int servoPin = 9;
int servoPin2 = 10;
int pulseWidth = 0;
int pulseWidth2 = 0;
long lastPulse = 0;
long lastPulse2 = 0;
int z_button = 0;
int c_button = 0;
int refreshTime = 20;
int minPulse = 1000;
int minPulse2 = 500;
int dtime=10;
#define pwbuffsize 10
long pwbuff[pwbuffsize];
long pwbuffpos = 0;
long pwbuff2[pwbuffsize];
long pwbuffpos2 = 0;
Serial.begin (9600);
Wire.begin ();
nunchuck_init ();
pinMode(servoPin, OUTPUT);
pinMode(servoPin2, OUTPUT);
pinMode(laserPin, OUTPUT);
pulseWidth = minPulse;
pulseWidth2 = minPulse2;
Serial.print ("Finished setupn");
void nunchuck_init()
Wire.beginTransmission (0x52);
Wire.write (0x40);
Wire.write (0x00);
Wire.endTransmission ();
void send_zero()
Wire.write (0x00);
int t = 0;
t++;
long last = millis();
if( t == 1) {
t = 0;
Wire.requestFrom (0x52, 6);
while (Wire.available ()) {
outbuf[cnt] = nunchuk_decode_byte (Wire.read ());
digitalWrite (ledPin, HIGH);
cnt++;
if (cnt >= 5) {
// printNunchuckData();
int z_button = 0;
int c_button = 0;
if ((outbuf[5] >> 0) & 1)
z_button = 1;
if ((outbuf[5] >> 1) & 1)
c_button = 1;
switch (c_button) {
case 1:
switch (z_button) {
case 0:
digitalWrite(laserPin, LOW);
muovi();
case 1:
digitalWrite(laserPin, HIGH);
muovi();
case 0:
switch (z_button) {
case 0:
case 1:
//delay(3000);
cnt = 0;
send_zero();
} // if(t==)
updateServo();
delay(dtime);
void updateServo()
if (millis() – lastPulse >= refreshTime) {
digitalWrite(servoPin, HIGH);
delayMicroseconds(pulseWidth);
digitalWrite(servoPin, LOW);
digitalWrite(servoPin2, HIGH);
delayMicroseconds(pulseWidth2);
digitalWrite(servoPin2, LOW);
lastPulse = millis();
int i=0;
void printNunchuckData()
int joy_x_axis = outbuf[0];
int joy_y_axis = outbuf[1];
int accel_x_axis = outbuf[2]; // * 2 * 2;
int accel_y_axis = outbuf[3]; // * 2 * 2;
int accel_z_axis = outbuf[4]; // * 2 * 2;
int z_button = 0;
int c_button = 0;
z_button = 1;
c_button = 1;
if ((outbuf[5] >> 2) & 1)
accel_x_axis += 2;
if ((outbuf[5] >> 3) & 1)
accel_x_axis += 1;
if ((outbuf[5] >> 4) & 1)
accel_y_axis += 2;
if ((outbuf[5] >> 5) & 1)
accel_y_axis += 1;
if ((outbuf[5] >> 6) & 1)
accel_z_axis += 2;
if ((outbuf[5] >> 7) & 1)
accel_z_axis += 1;
Serial.print (i,DEC);
Serial.print ("t");
Serial.print ("X: ");
Serial.print (joy_x_axis, DEC);
Serial.print ("t");
Serial.print ("Y: ");
Serial.print (joy_y_axis, DEC);
Serial.print ("t");
Serial.print ("AccX: ");
Serial.print (accel_x_axis, DEC);
Serial.print ("t");
Serial.print ("AccY: ");
Serial.print (accel_y_axis, DEC);
Serial.print ("t");
Serial.print ("AccZ: ");
Serial.print (accel_z_axis, DEC);
Serial.print ("t");
Serial.print (z_button, DEC);
Serial.print (" ");
Serial.print (c_button, DEC);
Serial.print ("rn");
i++;
char nunchuk_decode_byte (char x)
x = (x ^ 0x17) + 0x17;
return x;
void muovi ()
float tilt = (700 – outbuf[3]*2*2);
float tilt2 = outbuf[2]*2*2;
tilt = (tilt);
pulseWidth = (tilt * 5) + minPulse;
tilt2 = (tilt2-288);
pulseWidth2 = (tilt2 * 5) + minPulse2;
pwbuff[pwbuffpos] = pulseWidth;
pwbuff2[pwbuffpos2] = pulseWidth2;
if( ++pwbuffpos == pwbuffsize ) pwbuffpos = 0;
if( ++pwbuffpos2 == pwbuffsize ) pwbuffpos2 = 0;
pulseWidth=0;
pulseWidth2=0;
for( int p=0; p<pwbuffsize; p++ ){
pulseWidth += pwbuff[p];
pulseWidth2 += pwbuff2[p];
pulseWidth /= pwbuffsize;
pulseWidth2 /= pwbuffsize;
Hi AWOL
Pretty much when you get to void loop() section i get pretty lost. I would incorporate servo library, if i then knew which pieces to take out.
Having tried to compile the code i get these errors. Which i can't get my head around.
Have you read Robin2's post at the very top of this Forum? It's a good place to start and, if questions remain, goolge your question and read a few of the responses. When that's a little comfortable, start loading and looking at the code in the Examples directory (e.g., File --> Examples --> Basics --> Blink) and start playing around with the code.
The error is a Unicode character in the code which the IDE doesn't like. Character"en dash". If there's a - somewhere try deleting it and putting it back in.
The code that AWOL posted in reply #1 compiles for me but I suspect that he downloaded the ZIP file from the link in the original post.
The Unicode characters usually get there when you copy/paste from a Web page.
