noob
Hi there forum!!
I have a question: would you be able to change the arduino servo library so than you can tell the servo to stop for let's say 10 seconds at a certain time, before going on to the next programmed position? At the moment you can only control the time it takes to reach the position you want the servo to go to (10m/s) etc. Thank you!! Please help
You could modify the library I suppose,but why bother ? You already have full control over when the servo moves and stops and how many steps it makes during each move.
yup, just go to libraries/Servo in your the folder Arduino is installed (NOT the sketchbook folder); and modify the Servo.cpp file.
However, as UKHeliBob pointed out, there is no need to modify the library when you have full control of it.
And please try using meaningful names for your post titles in the future, the title 'Noob' doesn't give an insight into the problem/query that you have.
