Noobie with some questions
Sorry if this might be very easy to do, i just purchased my first arduino.
Basically i stream on twitch and use a green screen, currently its pvc piped frame with green cloth over it, i have to drag it out everytime i use it. I would really like to set up a motor to a pvc pip and hang it from the ceiling, so that when i press a button the fabric unrolls/rolls behind me. I would also like to tie in 2 LED panels that i use for lighting for the green screen and would love to be able to do all of this from a touch screen lcd screen. Curious to the coding required for this, what motor i would use for the green screen weight (fabric is about 5ft x 5ft) and how i would go about hooking up 2 LED panels to it as well. Any advice would be appreciated.
-Dave
Basically i stream on twitch and use a green screen, ...
what ? ? ? ?
Anyway, if you want to interface an arduino to a motor, some LED panels and an LCD/(TFT) touch screen, that is basically no problem.
You may require extra components (eg power supply) depending on exactly what peripheral devices you are using.
If you are a beginner, break the problem down into smaller parts and join it all up afterwards. For example, a touch screen is quite a complex device. Treat that as a separate activity at first and integrate it later in your project.
6v6gt:
what ? ? ? ?
Think he may be Chroma keying his background when you key you're replacing the background with basically any type of clip/video/photo you want they use it in the news industry all the time usually using the cities background or something similar
