Normally Closed Button
I am coding a roller coaster control panel. All of my buttons work apart from one red button (Called sstop in the program). I have one other NC button which works perfectly fine. I have tried changed it to == HIGH instead of LOW but all this does is repeatedly press the 's' button which isn't ideal, it doesn't even stop when you press it down.
Here is the program.
#include <Keyboard.h>
//Set Pin Values for buttons
const int power = 1;
const int reset = 2;
const int switch1 = 3;
const int switch2 = 4;
const int switch3 = 5;
const int switch4 = 6;
const int sstop = 7;
const int preshow = 8;
const int estop = 9;
const int gates = 10;
const int restraintsOPEN = 11;
const int restraintsCLOSED = 12;
const int tilt = 13;
const int selector = A0;
const int launch = A1;
const int dispatch = A2;
void setup(){
  // Pin modes
  pinMode(power, INPUT_PULLUP);
  pinMode(reset, INPUT_PULLUP);
  pinMode(switch1, INPUT_PULLUP);
  pinMode(switch2, INPUT_PULLUP);
  pinMode(switch3, INPUT_PULLUP);
  pinMode(switch4, INPUT_PULLUP);
  pinMode(sstop, INPUT_PULLUP);
  pinMode(preshow, INPUT_PULLUP);
  pinMode(estop, INPUT_PULLUP);
  pinMode(gates, INPUT_PULLUP);
  pinMode(restraintsOPEN, INPUT_PULLUP);
  pinMode(restraintsCLOSED, INPUT_PULLUP);
  pinMode(tilt, INPUT_PULLUP);
  pinMode(selector, INPUT_PULLUP);
  pinMode(launch, INPUT_PULLUP);
  pinMode(dispatch, INPUT_PULLUP);}
// Set variables for button states
int powerPOS = digitalRead(power);
int resetPOS = digitalRead(reset);
int switch1POS = digitalRead(switch1);
int switch2POS = digitalRead(switch2);
int switch3POS = digitalRead(switch3);
int switch4POS = digitalRead(switch4);
int sstopPOS = digitalRead(sstop);
int preshowPOS = digitalRead(preshow);
int estopPOS = digitalRead(estop);
int gatesPOS = digitalRead(gates);
int tiltPOS = digitalRead(tilt);
int selectorPOS = digitalRead(selector);
int launchPOS = digitalRead(launch);
int dispatchPOS = digitalRead(dispatch);
int prevestoppos = HIGH;
int power = 0;
// |===============================Station Controls===============================|
//Power (stops keyboard working when down)
if (powerPOS == LOW){ //When down
    power = 1;} //Power on
if (powerPOS == HIGH){
    power = 0;} //Off
 //Reset
 if (estopPOS == HIGH and resetPOS == LOW and power == 1){
  Keyboard.press('r');
  delay(100);
  Keyboard.releaseAll();}
//Station Stop
if (sstopPOS == LOW and power == 1){
  Keyboard.press('s');
  delay(100);
//Emergency Stop
if (estopPOS != prevestoppos and power == 1){
  Keyboard.press('e');
  delay(100);
  estopPOS = prevestoppos;}
//Grey switch 1
if (switch1POS == LOW){
  Keyboard.press('+');
  delay(100);
//Grey Switch 2
if (switch2POS == LOW){
  Keyboard.press('1');
  Keyboard.press('v');
  delay(100);
//Grey switch 3
if (switch3POS == LOW){
  Keyboard.press('-');
  delay(100);
//Grey switch 4
if (switch4POS == LOW){
  Keyboard.press('2');
  Keyboard.press('z');
  delay(100);
//Gates
if (gatesPOS == LOW and power == 1){
  Keyboard.press(KEY_RIGHT_ARROW);
  delay (100);
if (gatesPOS == HIGH and power == 1){
  Keyboard.press(KEY_LEFT_ARROW);
  delay (100);
//Restraints
if (digitalRead(restraintsOPEN) == LOW and power == 1){
  Keyboard.press(KEY_UP_ARROW);
  delay(100);
if (digitalRead(restraintsCLOSED) == LOW and power == 1){
  Keyboard.press(KEY_DOWN_ARROW);
  delay(100);
// Station Stop Button
if (tiltPOS == LOW and power == 1){ // If tilt is pressed
  Keyboard.press(KEY_RETURN); // Press enter for 4 seconds
  delay (100);
//2nd 2 pos switch/selector switch
//Launch Button
if (launchPOS == LOW and power == 1){ // If launch is pressed
  Keyboard.press('l'); // Press L
  delay (100);
// Dispatch Button
if (dispatchPOS == LOW and power == 1){ // If dispatch is pressed
  Keyboard.press(' '); // Press spacebar
  delay (100);
//Preshow doors/start
if (preshowPOS == LOW and power == 1){ // If preshow is pressed
  Keyboard.press(KEY_RETURN); // press return
  delay(100);
As you are using INPUT_PULLUP I presume when your switches are closed they pull the pin to GND. In that case I would expect a NC switch to report HIGH when pressed.
It would only take 5 minutes to write a short program to verify that.
I have no idea what this means
I don't see any variable called "s" - which would, in any case, be a lousy name.
As a separate matter if the RED SSTOP switch is an emergency switch and if there is a risk of people being injured I would make the switch work completely independently of the Arduino.
...R
//Emergency Stop
  delay(100);
in code line 89 you have to write the prevestoppos variable first.
like this... prevestoppos = estopPOS;
Robin2:
I have no idea what this meansI don't see any variable called "s" - which would, in any case, be a lousy name.
...R
I have tried changing it to HIGH but it repeatedly presses the 's' key, like the key on the keyboard, not a button called s.
The panel is for fun, there is no risk to life or limb, it is for a simulation game.
GrOnThOs:
//Emergency Stop
  delay(100);
Thanks I'll change it now!
