Not a big fan of using software written
by others in my programs. I refer of course to all these .h and .cpp files.
I have no idea how to read them or even how they relate to my program when my programs call them.
Is there a primer somewhere that will explain what is going on?
For example when I see something like
WiFiClient client; so what is that doing? Does the h or cpp file MUST be called that, or something inside only?
And suppose I want to see what sort of facilities are available in these programs, how do I read them. I double click and that nothing and then I open with textedit and still, there is not much documentation in the programs either.
I don’t even understand the :: thing I see often.
Any help would be wonderful, THANK YOU!
The great thing about the Open Source paradigm is that all the source code is on your computer and available to look at. If you don’t understand that code, then you’ll need to do some work learning the C++ programming language.
That is declaring a variable, named client, that is of type WiFiClient. Bog standard C and C++ coding.
Since WiFiClient is not a standard type like int or float or char, we can surmise that it must be class or struct.
There is not requirement that the name of the header file or the source file MUST match the class that it defines, but there IS a convention that says that they will. Often violated in Arduino land.
With a text editor.
On what operating system? On Windoze, there are default applications for a lot of types. If the type (based on the extension) is defined, the default application for that type will be started. If the type does not have a default application, Windoze will pop up a dialog telling you that, and suggesting what application might be useful. In Win10, this stupid dialog doesn't provide a way to say "never mind. I didn't mean to double click this file's icon".
A passable action. Not a great editor for code, but at least you can see the text.
Typically, the documentation is in the examples, not in the code. There are also some expectations that you know what a client is, what a server is, etc. So, you should not be expecting to find a "WiFiClient for Dummies" reference book in the source or header file.
I don't even understand the :: thing I see often.
Its time to take a class in object oriented programming, then.
thank you for replying, I just noticed I had asked this question priorly and I had never gotten an alert by email to look at it. I get lots of other emails of course from arduino.
sevenoutpinball:
.... then I open with textedit
You should use notepad++ , a free text editor with a lot possibilities.
...there is not much documentation in the programs either.
That's free , DIY software.
Regards,
bidouilleelec
does that run on a mac?
sevenoutpinball:
Notepad++?
I doubt
I use “Open declaration” function in Eclipse
do you see how left in project tree the file in the library folder is selected too?
now that looks interesting.
