Platform: Arduino -WiFi-rev2
Framewrok: Arduino
Compiler: AVR-GCC
Build System: PlatformIO
SoW:
Use MQTT protocol. Capture topic and payload to do some operation. The operation which I want to do here is calling a function from other class inside or outside the callback function to do some optiation based on the payload recieved from MQTT broker.
Problem:
- Not able to call any function inside a callback function of PubSubClient library.
- Next method I have tried is to assign data to a variable inside the callback method and return them. But didn't work either, as I am not able to capture the return values outside the fucntion.
Code snippet:
mqtt.cpp: callback method is mentioned as processData
void processData(char* topic, byte* payload, unsigned int length) {
// This just marks the termination of the char array.
payload[length] = '\0';
// Dumping the information into the log file
// *getLogFile() << "Topic received : " << topic << std::endl;
// *getLogFile() << "Message received : " << payload << std::endl;
// *getLogFile() << "Length of message : " << length << std::endl;
Serial.println("Topic received : " + String(topic));
Serial.println("Message received : " + String((char*)(payload)));
Serial.println("Length of message : " + String(length));
// Based on the message received from the broker, we either switch
// OFF or switch ON the led of the board
if((strcmp((char *)payload, "START")) == 0) {
digitalWrite(25, HIGH);
shields->setMotorMode(START_MOTOR);
//Debug message
Serial.println("Comapred Output for START: " + String((strcmp((char *)payload, "START"))));
Serial.println("Pin Number using getLed Method: ");
// Serial.println(led->getLedPin());
//Debug message ends
} else if ((strcmp((char *)payload, "STOP")) == 0) {
digitalWrite(25, LOW);
shields->setMotorMode(STOP_MOTOR);
//Debug message
Serial.println("Comapred Output for STOP: " + String((strcmp((char *)payload, "STOP"))));
//Serial.println(led->getLedPin());
else{
//digitalWrite(led->getLedPin(), LOW);
mqtt.cpp: (mqttSetup method)
void Mqtt::setupMqttClient() {
// *getLogFile() << "Broker address : " << getMqttServerAddress() << std::endl;
// *getLogFile() << "Port address : " << getMqttPortAddress() << std::endl;
// Connecting the client with the broker
*getLogFile() << "Setting up the boards's server configuration for \
connecting with the broker" << std::endl;
Serial.print("Broker address : ");
Serial.println(String(getMqttServerAddress()));
Serial.print("Port address : ");
Serial.println(getMqttPortAddress());
Serial.println("Setting up the boards's server configuration for \
connecting with the broker");
mqttClient.setServer(getMqttServerAddress(), getMqttPortAddress());
// Callback for receiving messages from broker
*getLogFile() << "Setting up the boards's callback function information for \
each message received by the subscriber" << std::endl;
Serial.println("Setting up the boards's callback function information for \
each message received by the subscriber");
// mqttClient.setCallback([this] (char* topic, byte* payload,
// unsigned int length) {
// this->processData (topic, payload, length);
//void (*ptr)(char*, byte*, unsigned int, Mqtt*) = &processData;
void (*ptr)(char*, byte*, unsigned int) = &processData;
mqttClient.setCallback(ptr);
// Converting the std::string into char array since setServer
// accepts only char[]. For some reason, it does not accept
// char* which we can get using std::string.c_str()
if (mqttClient.connect(getMqttClientId())) {
// *getLogFile() << "Connected the subscriber with the broker";
Serial.println("Connected the subscriber with the broker");
// Subscribe to topic
mqttClient.subscribe(getMqttTopicName());
// *getLogFile() << "Subscriber subscribed to the topic " << TOPIC_NAME << std::endl;
Serial.println("Subscriber subscribed to the topic: " + String(getMqttTopicName()));
Serial.println("Connection failed while connecting the subscriber \
with the broker.");
*getLogFile() << "Connection failed while connecting the subscriber \
with the broker." << std::endl;
The program compiles successfully.
Problem/Error:
This function is from the Motor drive library.
In this method the getLedPin() should return the pinnumber 25 which I have set in the literals. But actually return 49.
So my program is never working as expected.
Help me to find a way to capture the topic and the payoad from the callbackfunction and use it with some other class.
