Not able to flash Arduino Nano board
Hi, I am not able to flash Arduino pro nano board. I got following error. This is my first post and first try with arduino. I got error while flashing board. i was using blink example and i was selected board as "Arduino nano" and selected COM port properly. Following are the errors.
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "X:\DIY\arduino\arduino-1.8.1\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM9
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x25
Is that mean bootloader is not present in controller.
What is an Arduino Pro Nano? Do you mean Arduino Nano or Sparkfun Pro Micro? You need to select the right board. Post a link or a picture if you’re not sure.
If you are sure that it is an Arduino Nano:
Is this a genuine Arduino Nano, or a clone? If the latter, did you install the USB drivers?
Are you 100% sure that the COM port is correct (check Device Manager)?
Did you connect anything to pins 0 or 1?
