Not able to generate clock using hardware timer in esp32
#include <Arduino.h>
#include <esp32/rom/ets_sys.h>
#include <esp_timer.h>
const int switchPin = 34;  // GPIO pin where the switch is connected
const int pulsePin = 18;  // GPIO pin where the clock pulse output will be sent
volatile bool pulseEnabled = false;  // Flag to track whether pulse generation is enabled
esp_timer_handle_t timer_handle;  // Handle for the hardware timer
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;  // Mutex for timer ISR access
void IRAM_ATTR timer_callback(void* arg) {
    // Toggle the pulse pin state
    digitalWrite(pulsePin, !digitalRead(pulsePin));
    pinMode(switchPin, INPUT_PULLUP);  // Enable internal pull-up resistor for the switch
    pinMode(pulsePin, OUTPUT);
    digitalWrite(pulsePin, LOW);  // Ensure pulse pin starts low
    // Configure hardware timer
    const esp_timer_create_args_t timer_args = {
        .callback = &timer_callback,
        .name = "clock_timer"
    ESP_ERROR_CHECK(esp_timer_create(&timer_args, &timer_handle));
void IRAM_ATTR switch_isr() {
    portENTER_CRITICAL_ISR(&timerMux);
    if (digitalRead(switchPin) == LOW) {  // Switch pressed
        if (!pulseEnabled) {
            ESP_ERROR_CHECK(esp_timer_start_periodic(timer_handle, 1000000));  // Start timer, 1ms period
            pulseEnabled = true;
    } else {  // Switch released
        if (pulseEnabled) {
            ESP_ERROR_CHECK(esp_timer_stop(timer_handle));  // Stop the timer
            digitalWrite(pulsePin, LOW);  // Ensure pulse pin is low
    portEXIT_CRITICAL_ISR(&timerMux);
    attachInterrupt(digitalPinToInterrupt(switchPin), switch_isr, CHANGE);
    delay(100);  // Delay to avoid bouncing
not able to generate clock using hardware timer in esp32
Is this the same as
and this
and continuation of this:
Why did you still opened a new threads about your problem? Please continue the discussion inside a single topic. Duplicate threads is a violation of the forum rules.
