not able to host server on Ethernet shield with SD card in use
I am working on Arduino Mega and W5100 Ethernet shield. Trying to make an attendance system on local server using fingerprint module, RTC clock, and oled display in my Project.
The final program code, without the ethernet code is working fine. But when ethernet code is included in the program ... it is generating an IP but it is not able to create a server
server.begin() is not working ... Please Help.
#include <SPI.h>
#include <SD.h>
#include <DS3231.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
#include <Ethernet.h>
#define OLED_RESET 3
int CS_PIN = 4;
SoftwareSerial mySerial(11, 12);
DS3231  rtc(SDA, SCL);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Adafruit_SSD1306 display(OLED_RESET);
File file;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 7}; // ip in lan assigned to arduino
byte gateway[] = { 192, 168, 1, 10 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80);
String push[11][32];
  while (!Serial);
  pinMode(CS_PIN , OUTPUT);
  pinMode(10 , OUTPUT);
  digitalWrite(4,HIGH);
  digitalWrite(10,HIGH);
  digitalWrite(10,LOW);
  Ethernet.begin(mac, ip, subnet, gateway);
  server.begin();
  if(server.available())
    Serial.println("SERVER is active");
    Serial.println("SERVER is inactive");
  Serial.println(Ethernet.localIP());
  digitalWrite(4,LOW);
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  finger.getTemplateCount();
  Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
  Serial.println("Waiting for valid finger...");
  rtc.begin();
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  Serial.println("Initializing SD card...");
  if (SD.begin(CS_PIN))
    Serial.println("SD card is ready to use.");
    Serial.println("SD card initialization failed");
  int id=-1;
  //fingure print detection code
  uint8_t p = finger.getImage();
  if (finger.getImage() != FINGERPRINT_OK || finger.image2Tz()!=FINGERPRINT_OK || finger.fingerFastSearch()!=FINGERPRINT_OK)
      id=-1;
  else{
    Serial.print("Found ID #"); Serial.print(finger.fingerID);
    Serial.print(" with confidence of "); Serial.println(finger.confidence);
    id=finger.fingerID;
  file=SD.open("data.csv");
  if(file)
    Serial.println("File opened with success!");
    Serial.println("Error in opening data file");
  String temp="";
  char ch;
  int top=0,top1=0;
  while(file.available()){
    ch=file.read();
    if(ch=='\n'){
      temp+=ch;
      push[top][top1]=String(temp);
      top1=0;
      top++;
      temp="";
     else if(ch==','){
      top1++;
      temp="";
        temp+=ch;
  file.close();
  Serial.println("data ftom data file ");
  //Serial.println(push);
  for(int i=0;i<11;i++){
    for(int j=0;j<32;j++)
      Serial.print(push[i][j]+"\t");
  String sname="";
  if(id>0){
      sname=push[id][1];
      String tdate=rtc.getDateStr(),p="";
      int l=tdate.length();
      for(int i=0;i<l && tdate[i]!=':';i++)
          p=p+tdate[i];
      push[id][p.toInt()+1]=rtc.getTimeStr();
      SD.remove("data.csv");
      file = SD.open("data.csv", FILE_WRITE);
      file.print(push[i][j]+',');
    file.println();
      //writeToFile(push);
       file.close();
  display.clearDisplay();
  // text display tests
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  if(sname=="")
    display.println("WELCOME!");
    display.println("WELCOME!"+sname);
  display.print("DATE ");display.println(rtc.getDateStr());
  display.print("TIME "); display.println(rtc.getTimeStr());
  display.display();
  if(sname=="")
    delay(4000);
//Serial.println(server);
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
     while(client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
// delay(5000);
softwareserial on mega?
set pinMode for pin 4
after setting the initial state, let further SS pin handling to libraries
There is at least one thing wrong.
// change this
// to this
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
This may be misleading. The available function returns non-zero if there are characters available in the rx buffer. It has nothing to do with the server being active or not.
SurferTim:
Server.available() is not Stream.available()
Juraj:
Read the docs.
SurferTim:
Read the docs.
Ethernet - Arduino Reference
that is what I say, server.available() returns Client, not int
this code does the same
if (client)
server returns empty client when no client is available and Client class has operator bool () which returns false for empty client
https://github.com/arduino/Arduino/blob/master/libraries/Ethernet/src/EthernetServer.cpp
so nothing about server state.
From that doc:
Gets a client that is connected to the server and has data available for reading.
Returns a Client object; if no Client has data available for reading, this object will evaluate to false in an if-statement
If there are no bytes in any of the socket rx buffers, this call returns false (zero), whether or not there are clients connected. Using this call to determine if the server started is incorrect.
SurferTim:
this is not the same for different networking libraries. it is true for Ethernet and Ethernet2, but ESP8266WiFi returns a connected client without data available. And if I remember correct, WiFiEsp over AT firmware too, but I am not sure about it.
What you say may be true, but...
young_monk:
SurferTim:
What you say may be true, but...#include <Ethernet.h>
I hope OP did read answer #1 :slight_smile: and it helped and our discussion could be useful in general
