Not able to load sketch
I’m having trouble loading up a sketch update to a NodeMCU which has been running for ages but needed some network info updates. The error msg I’m getting is “Error compiling for board NodeMCU 1.0 (ESP-12E Module).”
I have been having similar problems with other sketches and it looks like a file path cannot be found, I’m hoping someone could give me some guidance on this.
Arduino: 1.8.5 (Windows 10), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)”
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Dieter\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Dieter\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dieter\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10805 -build-path C:\Users\Dieter\AppData\Local\Temp\arduino_build_452543 -warnings=none -build-cache C:\Users\Dieter\AppData\Local\Temp\arduino_cache_454766 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Dieter\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Dieter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\Dieter\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\Dieter\Documents\Arduino\Home Assistant\DHT22_MQTT_HASS\DHT22_MQTT_HASS.ino
GetFileAttributesEx C:\Users\Dieter\AppData\Local\Temp\arduino_cache_454766: The system cannot find the file specified.
Code
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <DHT.h>
#include <ArduinoJson.h>
#define MQTT_VERSION MQTT_VERSION_3_1_1
// Wifi: SSID and password
const char* WIFI_SSID = "HOMEROUTER";
const char* WIFI_PASSWORD = "PASSWORD";
// MQTT: ID, server IP, port, username and password
const PROGMEM char* MQTT_CLIENT_ID = "office_dht22";
const PROGMEM char* MQTT_SERVER_IP = "192.168.1.6";
const PROGMEM uint16_t MQTT_SERVER_PORT = 1883;
const PROGMEM char* MQTT_USER = "username";
const PROGMEM char* MQTT_PASSWORD = "password";
// MQTT: topic
const PROGMEM char* MQTT_SENSOR_TOPIC = "office/sensor1";
// sleeping time
const PROGMEM uint16_t SLEEPING_TIME_IN_SECONDS = 600; // 10 minutes x 60 seconds
// DHT - D1/GPIO5
#define DHTPIN 5
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
WiFiClient wifiClient;
PubSubClient client(wifiClient);
// function called to publish the temperature and the humidity
void publishData(float p_temperature, float p_humidity) {
  // create a JSON object
  // doc : https://github.com/bblanchon/ArduinoJson/wiki/API%20Reference
  StaticJsonBuffer<200> jsonBuffer;
  JsonObject& root = jsonBuffer.createObject();
  // INFO: the data must be converted into a string; a problem occurs when using floats...
  root["temperature"] = (String)p_temperature;
  root["humidity"] = (String)p_humidity;
  root.prettyPrintTo(Serial);
  Serial.println("");
        "temperature": "23.20" ,
        "humidity": "43.70"
  char data[200];
  root.printTo(data, root.measureLength() + 1);
  client.publish(MQTT_SENSOR_TOPIC, data, true);
// function called when a MQTT message arrived
void callback(char* p_topic, byte* p_payload, unsigned int p_length) {
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("INFO: Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASSWORD)) {
      Serial.println("INFO: connected");
      Serial.print("ERROR: failed, rc=");
      Serial.print(client.state());
      Serial.println("DEBUG: try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  // init the serial
  dht.begin();
  // init the WiFi connection
  Serial.print("INFO: Connecting to ");
  WiFi.mode(WIFI_STA);
  Serial.println(WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
    Serial.print(".");
  Serial.println("");
  Serial.println("INFO: WiFi connected");
  Serial.println("INFO: IP address: ");
  // init the MQTT connection
  client.setServer(MQTT_SERVER_IP, MQTT_SERVER_PORT);
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  client.loop();
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  if (isnan(h) || isnan(t)) {
    Serial.println("ERROR: Failed to read from DHT sensor!");
    return;
    //Serial.println(h);
    //Serial.println(t);
    publishData(t, h);
  Serial.println("INFO: Closing the MQTT connection");
  client.disconnect();
  Serial.println("INFO: Closing the Wifi connection");
  WiFi.disconnect();
  ESP.deepSleep(SLEEPING_TIME_IN_SECONDS * 1000000, WAKE_RF_DEFAULT);
  delay(500); // wait for deep sleep to happen
You could try restarting the Arduino IDE to see if clearing the cache will help.
You could try TEMPORARILY disabling your antivirus software for a single compilation to see if that's the source of the problem. I'm a bit skeptical whether that would cause this specific error but it is know to cause similar problems with the temporary build files. If that is the problem then you would need to whitelist the offending process/files/folders.
Thanks pert
Closed down and after rebooting this morning everything worked as it should. Easiest solution ever! :confused:
