i am using an arduino based platform dfrduino romeo v1.0
i have connected this board to 2 dc motors and 1 servo..servo is attached to pin 8
servo is working correctly as i runed a program to move servo to its extreme positions to and fro
it just moves a bit when i enter a input commands in serial monitor.
dc motor are working fine.
please help
thankyou
this is the code i used
#include <Servo.h>
Servo myservo;
//Standard PWM DC control
int E1 = 5; //M1 Speed Control
int E2 = 6; //M2 Speed Control
int M1 = 4; //M1 Direction Control
int M2 = 7; //M1 Direction Control
///For previous Romeo, please use these pins.
//int E1 = 6; //M1 Speed Control
//int E2 = 9; //M2 Speed Control
//int M1 = 7; //M1 Direction Control
//int M2 = 8; //M1 Direction Control
void stop(void) //Stop
digitalWrite(E1,LOW);
digitalWrite(E2,LOW);
void advance(char a,char b) //Move forward
analogWrite (E1,a); //PWM Speed Control
digitalWrite(M1,HIGH);
analogWrite (E2,b);
digitalWrite(M2,HIGH);
void back_off (char a,char b) //Move backward
analogWrite (E1,a);
digitalWrite(M1,LOW);
analogWrite (E2,b);
digitalWrite(M2,LOW);
void turn_L (char a,char b) //Turn Left
analogWrite (E1,a);
analogWrite (E2,b);
void turn_R (char a,char b) //Turn Right
analogWrite (E1,a);
analogWrite (E2,b);
void servochange(){
static int pos;
if (Serial.available()){
char ch=Serial.read();
if(isDigit(ch))
pos=ch;
{if(0<pos<180){
myservo.write(ch);
delay(2000);}
void setup(void)
{ myservo.attach(8,544,2400);
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
Serial.begin(9600); //Set Baud Rate
Serial.println("Run keyboard control");
void loop(void)
{servochange();
if(Serial.available()){
char val = Serial.read();
if(val != (0<val<180))
switch(val)
case 's'://Move Forward
advance (225,225); //move forward in max speed
case 'w'://Move Backward
back_off (225,225); //move back in max speed
case 'a'://Turn Left
turn_L (200,200);
case 'd'://Turn Right
turn_R (200,200);
case 'z':
Serial.println("Hello");
case 'g':
stop();
else stop();
