Hi. I’m trying to make an LED animation using
arduino uno and ws2812b .
im using #include <pgmspace.h>
#include “FastLED.h”
but the problem is, this message is keep coming out again and again
that i cannot able to resolve
“a function-definition is not allowed here before ‘{’ token"
Code:
void Ani1() {
//put qbert first frame
for (int passtime = 0; passtime < 2; passtime++) //display it 8 times
FastLED.clear();
for (int i = 0; i < NUM_LEDS; i++) {
leds = pgm_read_dword(&(Qbert01*)); //read array from flash*
* FastLED.show();*
* delay(400);*
* //put qbert second frame*
* FastLED.clear();*
* for (int i = 0; i < NUM_LEDS; i++) {
leds = pgm_read_dword(&(Qbert02)); //read array from flash*
* FastLED.show();*
* delay(400);*
* //put qbert THIRd frame*
* FastLED.clear();*
leds = pgm_read_dword(&(Qbert03)); //read array from flash*
* FastLED.show();*
* delay(400);*
* //put qbert 4 frame*
* FastLED.clear();*
leds = pgm_read_dword(&(Qbert04)); //read array from flash*
* FastLED.show();*
* delay(400);*
* //put qbert 5 frame*
* FastLED.clear();*
leds = pgm_read_dword(&(Qbert05)); //read array from flash*
* FastLED.show();*
* delay(400);*
Please post the COMPLETE program code (in code tags) and also the complete error message(s). They contain lots of useful information that you've left out.
Steve
ah …
i’m a beginner, so i missed that ,sorry for that…
Here’s my code (i submit it)
i was going to use button to control animations …
and the error message is
아두이노:1.8.13 (Mac OS X), 보드:“Arduino Uno”
In file included from /Users/heoseong-won/Downloads/LEDMatrixSerial_20/LEDMatrixSerial_20.ino:9:0:
/Users/heoseong-won/Documents/Arduino/libraries/FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.003
pragma message “FastLED version 3.003.003”
/Users/heoseong-won/Downloads/LEDMatrixSerial_20/LEDMatrixSerial_20.ino: In function ‘void loop()’:
LEDMatrixSerial_20:501:23: error: a function-definition is not allowed here before ‘{’ token
void startShow(int i) {
LEDMatrixSerial_20:519:42: error: a function-definition is not allowed here before ‘{’ token
void colorWipe(uint32_t color, int wait) {
LEDMatrixSerial_20:527:45: error: a function-definition is not allowed here before ‘{’ token
void theaterChase(uint32_t color, int wait) {
LEDMatrixSerial_20:542:24: error: a function-definition is not allowed here before ‘{’ token
void rainbow(int wait) {
LEDMatrixSerial_20:556:36: error: a function-definition is not allowed here before ‘{’ token
void theaterChaseRainbow(int wait) {
LEDMatrixSerial_20:578:13: error: a function-definition is not allowed here before ‘{’ token
void Ani1() {
LEDMatrixSerial_20:768:1: error: expected ‘}’ at end of input
"Adafruit_NeoPixel.h"를 위한 복수개의 라이브러리가 발견되었습니다
사용됨: /Users/heoseong-won/Documents/Arduino/libraries/Adafruit_NeoPixel
사용되지 않음: /Users/heoseong-won/Documents/Arduino/libraries/Adafruit_NeoPixel-master
exit status 1
LEDMatrixSerial_20.ino (59.9 KB)
You are missing the closing brace } for this line:-
if (newState == LOW && oldState == HIGH) {
and you are missing the closing brace for this line:-
You are also missing the closing braces for other functions too. The Ani1(), Ani2(), Ani3() and Ani4().
Hint:- Click on a closing brace and it will tell you what the opening brace was. Or click on the opening brace and that will highlight the closing brace.
In a function definition there must be the same number of opening braces as closing ones. It not ... well you have seen what happens.
i understood and fixed that ! but,
but i still have error messages saying,
/Users/heoseong-won/Downloads/LEDMatrixSerial_20/LEDMatrixSerial_20.ino: In function ‘void startShow(int)’:
LEDMatrixSerial_20:514:13: error: ‘Ani3’ was not declared in this scope
Ani3();
/Users/heoseong-won/Downloads/LEDMatrixSerial_20/LEDMatrixSerial_20.ino:514:13: note: suggested alternative: ‘Ani2’
Ani3();
Ani2
LEDMatrixSerial_20:515:13: error: ‘Ani4’ was not declared in this scope
Ani4();
/Users/heoseong-won/Downloads/LEDMatrixSerial_20/LEDMatrixSerial_20.ino:515:13: note: suggested alternative: ‘Ani2’
Ani4();
Ani2
/Users/heoseong-won/Downloads/LEDMatrixSerial_20/LEDMatrixSerial_20.ino: In function ‘void Ani2()’:
LEDMatrixSerial_20:685:13: error: a function-definition is not allowed here before ‘{’ token
void Ani3() {
LEDMatrixSerial_20:742:13: error: a function-definition is not allowed here before ‘{’ token
void Ani4() {
LEDMatrixSerial_20:771:1: error: expected ‘}’ at end of input
exit status 1
sorry to keep bothering you
i understood and fixed that ! but,,
You haven't understood it because I said:-
And you are still missing them.
Read this again:-
If you are using the Arduino IDE, click on Tools > Auto Format, or hold down the CTRL key and press T, that will auto-format your code and you will be able to see where the code is indented improperly because of missing closing brackets.
