Not able to save incoming data from GPS
I have this code
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 11, TXPin = 10;
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin);
int latitude;
int longitude;
  ss.begin(GPSBaud);
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void displayInfo()
  if (gps.location.isValid())
    Serial.print("\n");
    Serial.print(gps.location.lat(), 7);
    Serial.print("\t");
    Serial.print(gps.location.lng(), 7);
    Serial.print(F("INVALID"));
It does exactly what I want it to. It prints GPS coordinates in the serial monitor. But I want to use the GPS coordinates in a more advanced code which means I need to save the latitude and longitude.
If i replace this part of the code:
    Serial.print("\n");
    Serial.print("\t");
with
    Serial.print("\n");
    latitude = (gps.location.lat(), 7);
    Serial.print(latitude);
    Serial.print("\t");
    longitude = (gps.location.lng(), 7);
    Serial.print(longitude);
then the serial print prints only 7’s.
Somehow, someway, gps.location.lat() and gps.location.lng() can be called by direct serialprint functions, but they can’t be saved, then called. Any idea why?
is not the same as
Looks like you need
    latitude = gps.location.lat();
    Serial.print(latitude,7);
Correct... It actually also wants me to use float instead of int.
tbanari:
If you expected the latitude and longitude to be an int, what would the units be ?
tbanari:
What does "it" refer to?
@OP
Can you please, post a screenshot of your Serial Monitor that shows the values of the received latitude and longitude.
