I have been trying to send sms using the examples in the gsm library for gboard but the code for GSM_Shield_Test is not getting compiled.
I am using the below example(GSM_Shield_Test)....
/* GSM Shield example
created 2011
by Boris Landoni
This example code is in the public domain.
http://www.open-electronics.org
http://www.futurashop.it
#include <GSM_Shield.h>
char number[]="+39123456789"; //Destination number
char text[]="hello world"; //SMS to send
byte type_sms=SMS_UNREAD; //Type of SMS
byte del_sms=0; //0: No deleting sms - 1: Deleting SMS
GSM gsm;
char sms_rx[122]; //Received text SMS
//int inByte=0; //Number of byte received on serial port
char number_incoming[20];
int call;
int error;
Serial.println("system startup");
gsm.TurnOn(9600); //module power on
gsm.InitParam(PARAM_SET_1);//configure the module
gsm.Echo(0); //enable AT echo
char inSerial[5];
int i=0;
delay(2000);
Check_Call(); //Check if there is an incoming call
Check_SMS(); //Check if there is SMS
//Check data serial com
if (Serial.available() > 0)
while (Serial.available() > 0) {
inSerial[i]=(Serial.read()); //read data
i++;
inSerial[i]='\0';
Check_Protocol(inSerial);
void Check_Protocol(String inStr)
Serial.print("Command: ");
Serial.println(inStr);
Serial.println("Check_Protocol");
switch (inStr[0])
case 'a' : //Answer
if (gsm.CallStatus()==CALL_INCOM_VOICE){
gsm.PickUp();
Serial.println("Answer");
Serial.println("No incoming call");
case 'c': // C //Call
if (inStr.length()<2) //To call variable 'number' comand c
Serial.print("Calling ");
Serial.println(number);
gsm.Call(number);
if (inStr.length()==2) //To call number in phone book position comand cx where x is the SIM position
error=gsm.GetPhoneNumber(inStr[1],number);
if (error!=0)
gsm.Call(number);
Serial.print("No number in pos ");
Serial.println(inStr[1]);
case 'h': //H //HangUp if there is an incoming call
if (gsm.CallStatus()!=CALL_NONE)
Serial.println("Hang");
gsm.HangUp();
case 's': //S //Send SMS
Serial.print("Send SMS to ");
error=gsm.SendSMS(number,text);
if (error==0) //Check status
Serial.println("SMS ERROR \n");
Serial.println("SMS OK \n");
case 'p': //Read-Write Phone Book
if (inStr.length()==3)
switch (inStr[1])
case 'd': //Delete number in specified position pd2
error=gsm.DelPhoneNumber(inStr[2]);
if (error!=0)
Serial.print("Phone number position ");
Serial.print(inStr[2]);
Serial.println(" deleted");
case 'g': //Read from Phone Book position pg2
error=gsm.GetPhoneNumber(inStr[2],number);
if (error!=0) //Find number in specified position
Serial.print("Phone Book position ");
Serial.print(": ");
else //Not find number in specified position
Serial.print("No Phone number in position ");
Serial.println(inStr[2]);
case 'w': //Write from Phone Book Position pw2
error=gsm.WritePhoneNumber(inStr[2],number);
if (error!=0)
Serial.print("Number ");
Serial.print(number);
Serial.print(" writed in Phone Book position ");
else Serial.println("Writing error");
delay(1500);
return;
void Check_Call() //Check status call if this is available
call=gsm.CallStatus();
switch (call)
case CALL_NONE:
Serial.println("no call");
case CALL_INCOM_VOICE:
gsm.CallStatusWithAuth(number_incoming,0,0);
Serial.print("incoming voice call from ");
Serial.println(number_incoming);
case CALL_ACTIVE_VOICE:
Serial.println("active voice call");
case CALL_NO_RESPONSE:
Serial.println("no response");
return;
void Check_SMS() //Check if there is an sms 'type_sms'
char pos_sms_rx; //Received SMS position
pos_sms_rx=gsm.IsSMSPresent(type_sms);
if (pos_sms_rx!=0)
//Read text/number/position of sms
gsm.GetSMS(pos_sms_rx,number_incoming,sms_rx,120);
Serial.print("Received SMS from ");
Serial.print(number_incoming);
Serial.print("(sim position: ");
Serial.print(word(pos_sms_rx));
Serial.println(")");
Serial.println(sms_rx);
if (del_sms==1) //If 'del_sms' is 1, i delete sms
error=gsm.DeleteSMS(pos_sms_rx);
if (error==1)Serial.println("SMS deleted");
else Serial.println("SMS not deleted");
return;
I am getting the following error on compiling the above code
In file included from GSM_Shield_Test.pde:14:
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h:10:22: error: WProgram.h: No such file or directory
In file included from C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h:11,
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h:152: error: 'byte' does not name a type
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h:161: error: 'byte' has not been declared
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h: In member function 'void GSM::SetCommLineStatus(int)':
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h:161: error: 'comm_line_status' was not declared in this scope
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h: In member function 'void GSM::DisableUserButton()':
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h:206: error: 'module_status' was not declared in this scope
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h: In member function 'void GSM::EnableUserButton()':
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.5\libraries\GSM_Shield/GSM_Shield.h:207: error: 'module_status' was not declared in this scope
GSM_Shield_Test.pde: In function 'void Check_Protocol(String)':
GSM_Shield_Test:74: error: 'class GSM' has no member named 'CallStatus'
GSM_Shield_Test:110: error: 'class GSM' has no member named 'CallStatus'
GSM_Shield_Test.pde: In function 'void Check_Call()':
GSM_Shield_Test:198: error: 'class GSM' has no member named 'CallStatus'
GSM_Shield_Test:205: error: 'class GSM' has no member named 'CallStatusWithAuth'
