Not able to upload sketches after adding exit (0) to last sketch.. please help.
The last sketch I uploaded into my ATMega32U4 added the command "exit (0) ;" to close the loop from running on and on... only ever since it's uploaded, I can't upload any new sketches to the board. Does anyone have any advice on what I can do? When I plug the board into a computer it still produces the text from the most recent program, so it's still on there, but I'm thinking that the exit command did more than I expected somehow and perhaps shut the board down after running it???? I was using ABRISP mkll to upload before, and still using it now to (not) upload.
Here's the sketch:
#include "Keyboard.h"
Keyboard.begin();
Keyboard.print(F("25k code was here but I replaced it with this text")) ;
Keyboard.end() ;
exit(0) ;
When I try to upload anything now, I get this error message:
Sketch uses 3620 bytes (12%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes (5%) of dynamic memory, leaving 2411 bytes for local variables. Maximum is 2560 bytes.
avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ""; type = �
Software Version = a.�; Hardware Version = �.�
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
jerbee:
What do you mean by that? Are you saying that you actually have an AVRISP mkII connected to the ICSP header (or the equivalent pins) and are doing a Sketch > Upload Using Programmer to upload? Or are you saying that you are doing a standard Upload using a USB cable directly connected to the ATmega32U4 board and just happen to have Tools > Programmer > AVRISP mkII selected?
