Not Activating Relay
I have this wired up and configured and when I place the appropriate weight on it. I think it is solved; however, it never pushes to the relay. Anyone see anything wrong with it.
// DEFINES
// Flag to toggle debugging output
#define DEBUG
// Calibration mode to read measurements when the scale is first set up
#define CALIBRATE
// INCLUDES
// Library for interfacing with the HX711 24bit ADC module based on https://github.com/bogde/HX711
#include <HX711.h>
// Allows calibration data to be stored on the Arudino EEPROM
#include <EEPROM.h>
// CONSTANTS
// Simple signature in first byte of EEPROM indicates stored data is valid
const byte eepromSignature = 100;
// Pin which will be driven HIGH when the puzzle is solved
const byte lockPin = 2;
// The total weight of items which players have to place
const int solutionWeight = 476;
// The allowed difference between the measured weight and
// the desired "solution" weight (in grams).
const int tolerance = 10;
// GLOBALS
// Initialise the load cell module, parameters are Data(Out), Clock pin
HX711 scale;
// The correct scaleFactor value will be determined by running with the CALIBRATE flag set
float scaleFactor = -1315.3f;
// Track state of overall puzzle
enum PuzzleState {Initialising, Running, Solved};
PuzzleState puzzleState = Initialising;
// Loads stored calibration data from EEPROM
void loadCalibration(){
  // Check that the EEPROM starts with a valid signature
  if (EEPROM.read(0) == eepromSignature){
    // Load the calibration data
    EEPROM.get(1, scaleFactor);
    #ifdef DEBUG
      Serial.print("Calibration data loaded from EEPROM. Scale factor set to ");
      Serial.println(scaleFactor);
    #endif
  else {
    #ifdef DEBUG
      Serial.println("No valid calibration data found");
    #endif
// Saves calibration data to EEPROM
void saveCalibration(){
  // Erase the existing signature
  EEPROM.write(0, 0);
  // Write the pattern starting from first byte
  EEPROM.put(1, scaleFactor);
  // Now write the signature back again to byte zero to show valid data
  EEPROM.write(0, eepromSignature);
  #ifdef DEBUG
    Serial.println("Calibration data saved to EEPROM");
  #endif
// This method is called when the puzzle is solved
void onSolve() {
  // Activate the relay to supply power to the maglock
  digitalWrite(lockPin, HIGH);
  // Wait for one second
  // De-activate the relay again
  digitalWrite(lockPin, LOW);
  // The puzzle has now been solved
  puzzleState = Solved;
  // The serial monitor is required for debugging and calibration
  #if defined(DEBUG) || defined(CALIBRATE)
  #endif
  // Start the connection to the HX711 module on specified Data / Clock pins
  scale.begin(A0, A1);
  // The steps required to calibrate the scale are also described at https://github.com/bogde/HX711
  #ifdef CALIBRATE
    Serial.println(F("Calibrating..."));
    // 1. Set scale to 1.0
    scale.set_scale();
    // 2. Calculate the unladen (tare) weight when there is
    // no load, which will be used to offset subsequent readings.
    scale.tare();
    // 3. Obtain reading of known weight
    Serial.println(F("Place a known weight on the scale"));
    Serial.println(F("And type its mass in grams into the Arduino IDE Serial Monitor"));
    // Wait until the user types the mass over the serial input
    while (!Serial.available()){ ; }
    // Read the user input and store the weight
    int knownWeight = Serial.parseInt();
    // Calculate an average reading from the ADC for the known weight
    float reading = scale.get_units(10);
    // 4. Calculate scale factor from the reading of the known weight
    scaleFactor = reading / (float)knownWeight;
    Serial.print(F("Scale factor calculated: "));
    Serial.println(scaleFactor, 1);
    // 5. Save the scale factor to EEPROM
    saveCalibration();
    // Calibration complete
    Serial.println(F("Now remove the weight"));
    Serial.println(F("and send 'y' to continue"));
    // Wait until 'y' input is sent over the serial input before continuing
    while (Serial.read() != (unsigned char)'y') {;}
    Serial.println(F("Calibration complete. You may now remove #define CALIBRATE code line"));
  // If we're not in calibration mode
  #else
    // Load the calibrated scale factor from EEPROM
    loadCalibration();
  #endif
  // Set the scale based on the calculated/stored scale factor
  scale.set_scale(scaleFactor);
  // Reset the weight reading when nothing present
  scale.tare();
  // Initialise the relay pin
  pinMode(lockPin, OUTPUT);
  puzzleState = Running;
// Main program loop
  // Action to take depends on the current state of the puzzle
  switch(puzzleState) {
    case Running:
      // Take an average of 5 readings from the scale,
      // accounting for tare offset and scale factor
      int value = (int)(scale.get_units(5));
      #ifdef DEBUG
        Serial.print("Reading : ");
        Serial.println(value);
      #endif
      // If the reading is within tolerance of the correct value
      if(abs(value - solutionWeight) < tolerance) {
        onSolve();
    case Solved:
Have you considered adding a DEBUG Serial output line, within onSolve() to see if onSolve() is actually called ? or approaching it from the opposite end, have you tried 'blinking' the relay ?
Just out of curiosity how are you driving the relay?
To be honest I am really new to Arduino and most of that code was written by someone else who I know longer have contact with. So not quite sure what either of your are suggesting....sorry lol
i mean modify the function onSolve() like this :
void onSolve() {
  #ifdef DEBUG                            // add these lines
    Serial.println("Puzzle solved !");
  #endif
to see if onSolve() is actually executed
and to verify that the hardware is working as it is supposed to upload this sketch
