I'm trying out some concepts for a stepper motor control. I use the first part of this sketch successfully in the setup portion of the sketch. I added then next two parts and put into the loop. I get this error flagged only in the third WHILE loop, not in the first two.
"counter' was not declared in this scope"
I don't see why only that one is a porblem.
Here is the sketch:
#define motorPin1 8 //Blue |
#define motorPin2 9 //Pink | to plug
#define motorPin3 10 //Yellow > connector
#define motorPin4 11 //Orange | on ULN2003
// Red (VCC) |
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
int counter = 0;
while (counter < 512) {
digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, HIGH);
delay(7);
digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, HIGH); digitalWrite(motorPin4, HIGH);
delay(7);
digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, HIGH); digitalWrite(motorPin4, LOW);
delay(7);
digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, HIGH); digitalWrite(motorPin3, HIGH); digitalWrite(motorPin4, LOW);
delay(7);
digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, HIGH); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW);
delay(7);
digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, HIGH); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW);
delay(7);
digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW);
delay(7);
digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, HIGH);
delay(7);
counter = counter + 1;
if (counter = 512) {
Serial.print("count is ");
Serial.println(counter);
Serial.println("Aspect is Approach")
delay(2000);
while (counter < 1024) {
delay(7);
delay(7);
delay(7);
delay(7);
delay(7);
delay(7);
delay(7);
if (counter = 1024) {
Serial.println("Aspect is Clear")
delay(2000);
while (counter > 0) { //**<------THIS IS WHAT GETS FLAGGED**
delay(7);
delay(7);
delay(7);
delay(7);
delay(7);
delay(7);
delay(7);
counter = counter - 1;
if (counter = 0) {
Serial.println("Aspect is Stop")
