Howdy! I have a "was not declared in this scope error" for two elements, "recvOneChar()" and "showAndSaveNewData();", both in lines 78 and 79 of the code. I think I might have a bracket error yet can't figure it out, any help is appreciated.
//LCD & IR initial config:
#include <SPI.h>
#include <SD.h>
LiquidCrystal_I2C lcd (0x27, 16, 2);
const byte PulsesPerRevolution = 2;
const unsigned long ZeroTimeout = 100000;
const byte numReadings = 2;
volatile unsigned long LastTimeWeMeasured;
volatile unsigned long PeriodBetweenPulses = ZeroTimeout + 1000;
volatile unsigned long PeriodAverage = ZeroTimeout + 1000;
unsigned long FrequencyRaw;
unsigned long FrequencyReal;
unsigned long RPM;
unsigned int PulseCounter = 1;
unsigned long PeriodSum;
unsigned long LastTimeCycleMeasure = LastTimeWeMeasured;
unsigned long CurrentMicros = micros();
unsigned int AmountOfReadings = 1;
unsigned int ZeroDebouncingExtra;
unsigned long readings[numReadings];
unsigned long readIndex;
unsigned long total;
unsigned long average;
#define button_pin 7
//BOTON initial config:
// variables will change:
int button_press_count = 0;
int button_state = 0;
int prev_button_state = 0;
//SD
const int chipSelect = 4;
char receivedChar;
boolean newData = false;
lcd.init();
lcd.backlight();
attachInterrupt(digitalPinToInterrupt(2), Pulse_Event, RISING);
delay(100);
pinMode (button_pin, INPUT_PULLUP); //Set digi pin 7 as pull up button
pinMode (13, OUTPUT);
Serial.println("Button Count:");
//SD
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
Serial.println("<Arduino is ready>");
recvOneChar();
if (CurrentMicros < LastTimeCycleMeasure) {
LastTimeCycleMeasure = CurrentMicros;
FrequencyRaw = 10000000000 / PeriodAverage;
if (PeriodBetweenPulses > ZeroTimeout - ZeroDebouncingExtra || CurrentMicros - LastTimeCycleMeasure > ZeroTimeout - ZeroDebouncingExtra) {
FrequencyRaw = 0; // Set frequency as 0.
ZeroDebouncingExtra = 2000;
ZeroDebouncingExtra = 0;
FrequencyReal = FrequencyRaw / 10000;
RPM = FrequencyRaw / PulsesPerRevolution * 60;
RPM = RPM / 10000;
total = total - readings[readIndex];
readings[readIndex] = RPM;
total = total + readings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= numReadings) {
readIndex = 0;
average = total / numReadings;
button_state = digitalRead(button_pin);
if (button_state != prev_button_state) {
if (button_state == HIGH) {
digitalWrite(13, LOW);
} else { //button press
digitalWrite(13, HIGH);
button_press_count++;
Serial.println(button_press_count); //print the count
delay(50);
prev_button_state = button_state;
Serial.print("Period: ");
Serial.print(PeriodBetweenPulses);
Serial.print("\tReadings: ");
Serial.print(AmountOfReadings);
Serial.print("\tFrequency: ");
Serial.print(FrequencyReal);
Serial.print("\tRPM: ");
Serial.print(RPM);
Serial.print("\tTachometer: ");
Serial.println(average);
lcd.setCursor(0, 0);
lcd.print("RPM : ");
lcd.print(average);
lcd.print(" ");
lcd.setCursor(0, 1);
lcd.print("# vueltas : ");
lcd.print(button_press_count);
void Pulse_Event() {
PeriodBetweenPulses = micros() - LastTimeWeMeasured;
LastTimeWeMeasured = micros();
if (PulseCounter >= AmountOfReadings) {
PeriodAverage = PeriodSum / AmountOfReadings;
PulseCounter = 1;
PeriodSum = PeriodBetweenPulses;
int RemapedAmountOfReadings = map(PeriodBetweenPulses, 40000, 5000, 1, 10);
RemapedAmountOfReadings = constrain(RemapedAmountOfReadings, 1, 10);
AmountOfReadings = RemapedAmountOfReadings;
PulseCounter++;
PeriodSum = PeriodSum + PeriodBetweenPulses;
