Not declared in the scope
Hello all,
I do not understand why I get this error message:
C:\Users\mateusz.winter\Desktop\Beehive_data\Beehive_data.ino: In function 'void loop()':
Beehive_data:248:6: error: 'h' was not declared in this scope
 if ( h > 60 ) // If the humidity if greater than 60%
Multiple libraries were found for "DHT.h"
 Used: C:\Program Files (x86)\Arduino\libraries\DHT_sensor_library
 Not used: C:\Program Files (x86)\Arduino\libraries\DHT-sensor-library-master
exit status 1
Probably because you did not define h.
But your code is secret, so I can only guess.
The error is pretty self explaining I would say. H isn't defined, at least not in the scope you try to use it.
Plus for posting the whole error.
But fat minus for not posting the actual code...
 * File:   main.c
 * Company: RIOU Glass
 * Author: Mateusz WINTER
 * Project: This project is to monitor temperature and humidity
 * in a beehive by logging and saving data on SD card
// Configuration for DHT Sensor
 #include <DHT.h>
 #define DHTPIN 2
 #define DHTTYPE DHT11
 DHT dht(DHTPIN, DHTTYPE);
 // Configuration for RTC Module
// DS1302 RST  -> Arduino Digital 7
// DS1302 DATA -> Arduino Digital 6
// DS1302 CLK  -> Arduino Digital 5
#include <virtuabotixRTC.h>
virtuabotixRTC myRTC(6, 7, 8);
// Configuration SD card module
// SD card attached to SPI bus as follows:
// MOSI - pin 11
// MISO - pin 12
// CLK - pin 13
// CS - pin 4
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
// Temperature sensors
float Temp_1;
float Temp_2;
// Delay
//unsigned long seconds = 1000L; // 1000ms to 1s
//unsigned long minutes = seconds * 900; // 900s in 15 minutes
const unsigned long interval = 60000 ; // 90 minutes is 900000
unsigned long previous = 0 ;
const unsigned long intervala = 1000 ;
unsigned long previousa = 0 ;
// Fan and heater
const int HEATER = 10; //Red LED turn on heater
const int FAN = 9; //Blue LED turn on fan
void setup () {
  Serial.begin(9600); // Baud rate of 9600
  pinMode(chipSelect, OUTPUT);
// Heater and fan
  pinMode(HEATER,OUTPUT);
  pinMode(FAN,OUTPUT);
  digitalWrite(HEATER,LOW);
  digitalWrite(FAN,LOW);
// Set the current date, and time in the following format:
// seconds, minutes, hours, day of the week, day of the month, month, year
  myRTC.setDS1302Time(00, 17, 11, 6, 25, 06, 2019);
  Serial.println(F("Beehive data logger"));
  while (!Serial) {
  Serial.print("Starting SD card...");
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed to start or not present");
    while (1);
  Serial.println("   Card is now operational!");
  dht.begin();
  File dataFile = SD.open("testing.txt", FILE_WRITE);
// Printing column name for date, time, Temp_1, Temp_2, Temp_DHT and Humidity on serial terminal
  delay(100);
  Serial.print("Date      "); // Print header name for column
  Serial.print(" \t");        // Create tab/space
  Serial.print("Time      "); // Print header name for column
  Serial.print("Humidity in %"); // Print header name for column
  Serial.print("Temp_DHT in °C"); // Print header name for column
  Serial.print("Temp_1 in °C"); // Print header name for column
  Serial.print("Temp_2 in °C"); // Print header name for column
  Serial.println();  // Insert a new line
// Printing column name for date, time, Temp_1, Temp_2, Temp_DHT and Humidity on SD card
  dataFile.print("Date      "); // Print header name for column
  dataFile.print(" \t");        // Create tab/space
  dataFile.print("Time      "); // Print header name for column
  dataFile.print("Humidity in %"); // Print header name for column
  dataFile.print("Temp_DHT in °C"); // Print header name for column
  dataFile.print("Temp_1 in °C"); // Print header name for column
  dataFile.print("Temp_2 in °C"); // Print header name for column
  dataFile.println();  // Insert a new line
  dataFile.close();
  unsigned long current = millis();
  unsigned long currenta = millis();
  if(current - previous >= interval) {
  // This allows for the update of variables for time or accessing the individual elements.                //
  myRTC.updateTime();
  // Read the humidity of the DHT11
  float h = dht.readHumidity();
  // Read temperature as Celsius
  float t = dht.readTemperature();
  Temp_1 = analogRead(A0)*5/1023.0; // Read value from analog port A0 voltage range 0V - 5V 1023 is to convert the 10 bit number to a voltage reading.
  Temp_1 = Temp_1 - 0.5;
  Temp_1 = Temp_1 / 0.01;
  Temp_1 = Temp_1 - 2.0;
  Temp_2 = analogRead(A1)*5/1023.0; // Read value from analog port A1 voltage range 0V - 5V 1023 is to convert the 10 bit number to a voltage reading.
  Temp_2 = Temp_2 - 0.5;
  Temp_2 = Temp_2 / 0.01;
  Temp_2 = Temp_2 - 5.0;
  if (dataFile){
// Save to SD card
  dataFile.print("");
  dataFile.print(myRTC.dayofmonth);
  dataFile.print("/");
  dataFile.print(myRTC.month);
  dataFile.print(myRTC.year);
  dataFile.print("       ");
  dataFile.print(myRTC.hours);
  dataFile.print(":");
  dataFile.print(myRTC.minutes);
  dataFile.print(myRTC.seconds);
  dataFile.print(F(""));
  dataFile.print(h);
  dataFile.print(F("%  "));
  dataFile.print(t);
  dataFile.print(Temp_1); // Print temperature from temperature sensor 1
  dataFile.print(Temp_2); // Print temperature from temperature sensor 2
  dataFile.println();
  dataFile.close();
// Print to serial
  Serial.print("");
  Serial.print(myRTC.dayofmonth);
  Serial.print("/");
  Serial.print(myRTC.month);
  Serial.print("/");
  Serial.print(myRTC.year);
  Serial.print("       ");
  Serial.print(myRTC.hours);
  Serial.print(":");
  Serial.print(myRTC.minutes);
  Serial.print(":");
  Serial.print(myRTC.seconds);
  Serial.print(F(""));
  Serial.print(h);
  Serial.print(F("%  \t"));
  Serial.print(t);
  Serial.print(Temp_1); // Print temperature from temperature sensor 1
  Serial.print(Temp_2); // Print temperature from temperature sensor 2
  else {
    Serial.println("There has been an error saving data");
  previous = current ;
// Temperature and humidity control
if ( currenta - previousa >= intervala) {
Serial.print(h);
Serial.println(Temp_1); // Print temperature from temperature sensor 1
if(Temp_1 > 40) // Set the temperature
   digitalWrite(FAN,HIGH);
  digitalWrite(HEATER,HIGH);
      previousa = currenta ;
  digitalWrite(HEATER, LOW);
  digitalWrite(FAN, HIGH);
  digitalWrite(FAN, LOW);
Objects defined inside { } are only visible inside the same { }.
That concept is called scope, you should get familiar with it.
Looks to me you declared h inside this if statement, and are trying to access it outside the if statement.
I see so I need to declare the float h inside the scope? If so would it be inside the loop function of after the if ( h > 60 )?
In line 146 you declare a float variable h.
And in line 227 you declare another float variable h.
Both of those declarations are inside of if blocks. As soon as the if is finished the variable h goes out of scope (ceases to exist). It may be better to declare the variable in global scope. And declare only one h variable. In your original code, the 2 h variables are not the same.
