not declared in this scope? can you help me
#include <Servo.h>
Servo mijnServo;
int pos = 0;
int speakerpin = 7;
int RPin = 13;
int LPin = 12;
int ldrPin=0;
int times=0;
pinMode(LPin, OUTPUT);
pinMode(RPin, OUTPUT);
pinMode(ldrPin, INPUT);
mijnServo.attach(9);
int licht = analogRead(ldrPin);
if (licht <50) {
times=times+1;
if (times==1){
start2(); //here is where the problem is (not declared in this scope)
if (times==2){
start3();
if(times==3){
start4();
times=0;
void start2() {
digitalWrite(RPin, HIGH);
for (pos=0;pos<90;pos=pos+1){
mijnServo.write(pos);
delay(600);
for (pos=90;pos>=1;pos=pos-1){
delay(120);
digitalWrite(LPin, HIGH);
delay(400);
digitalWrite(RPin, LOW);
digitalWrite(LPin, LOW);
delay(200);
void start3() {
//for (int k=0;k<1;k++){
delay(300);
delay(200);
delay(300);
start4() {
delay(250
delay(250
You need to start with putting EVERY { on a line BY ITSELF. Then, try to use Tools + Auto Format. You can't, because you are missing a } at the end of your code.
After you add that, and Auto Format does its job, get rid
of the excessive
blank lines in
your code.
You'll see that start2() is declared INSIDE of loop(), and that is NOT allowed.
You have a ton of other errors, too.
 delay(250
oops
