"Not declared in this scope" Error with Libraries
Hi guys,
I’m working on a library to control a robot car. I have a class called “awesomeRobot”. I create an instance of it called “bot.” In my loop, I attempt to call functions from my library, e.g. bot.forward(), and I get an error message saying that “bot was not declared in this scope.” I can’t seem to make this work. Can anybody tell me what I’m missing here?
Header:
//  awesomeRobot.hpp
#ifndef awesomeRobot_h
#define awesomeRobot_h
#include "Arduino.h"
class awesomeRobot
public:
    awesomeRobot();
    void startAwesomeRobot();
    void forward(int duration, int realSpeed);
    void reverse(int duration, int realSpeed);
    void curveRight(int radius, int duration, int realSpeed);
    void curveLeft(int radius, int duration, int realSpeed);
    void pivotRight(int duration, int realSpeed);
    void pivotLeft(int duration, int realSpeed);
    void stopBot();
    int motor1 = 6;
    int motor2 = 7;
    int motor3 = 8;
    int motor4 = 9;
    int ENA = 5;
    int ENB = 11;
#endif /* awesomeRobot_h */
CPP:
//  awesomeRobot.cpp
#include "awesomeRobot.h"
awesomeRobot::awesomeRobot(){
void awesomeRobot::startAwesomeRobot(){
    pinMode(motor1, OUTPUT);
    pinMode(motor2, OUTPUT);
    pinMode(motor3, OUTPUT);
    pinMode(motor4, OUTPUT);
    pinMode(ENA, OUTPUT);
    pinMode(ENB, OUTPUT);
void awesomeRobot::forward(int duration, int realSpeed){
    analogWrite(ENA, realSpeed * 2.55);
    analogWrite(ENB, realSpeed * 2.55);
    digitalWrite(motor1, HIGH);
    digitalWrite(motor2, LOW);
    digitalWrite(motor3, LOW);
    digitalWrite(motor4, HIGH);
    delay(duration);
void awesomeRobot::reverse(int duration, int realSpeed){
    digitalWrite(motor1, LOW);
    digitalWrite(motor2, HIGH);
    digitalWrite(motor3, HIGH);
    digitalWrite(motor4, LOW);
    delay(duration);
void awesomeRobot::curveRight(int radius, int duration, int realSpeed){
    analogWrite(ENA, realSpeed * 2.55 / radius);
    analogWrite(ENB, realSpeed);
    delay(duration);
void awesomeRobot::curveLeft(int radius, int duration, int realSpeed){
    analogWrite(ENB, realSpeed * 2.55 / radius);
    delay(duration);
void awesomeRobot::pivotRight(int duration, int realSpeed){
    analogWrite(ENA, realSpeed);
    delay(duration);
void awesomeRobot::pivotLeft(int duration, int realSpeed){
    delay(duration);
void awesomeRobot::stopBot(){
    digitalWrite(ENA, LOW);
    digitalWrite(ENB, LOW);
Main Program:
#include <awesomeRobot.h>
  awesomeRobot bot;
  bot.startAwesomeRobot();
  bot.forward(1000, 90);
  bot.stopBot();
  bot.reverse(1000, 90);
  bot.stopBot();
Error Message:
Arduino: 1.6.11 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/evanjohnson/Desktop/Robot_Library_Test/Robot_Library_Test.ino: In function 'void loop()':
Robot_Library_Test:11: error: 'bot' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
When you deal with Libraries, you (usually) have to create an instance of that class.
You have to crerate that instance before the setup part of your sketch.
The way you made it, it is only visible inside the setup() part of the sketch... Not in the loop
It might look something likeawesomeRobot bot;
Read the documentation and/or the examples
Jacques
  awesomeRobot bot;
A variable declared in setup() goes out of scope as soon as setup() is finished. Bot is a variable of the type awesomeRobot. Declare bot in global scope to fix the error.
The code is now compiling and running properly! Thanks for the help guys! :slight_smile:
Motor Test
Just see if the robot can move and turn.
Circuit:
  • Arduino Robot
created 1 May 2013
by X. Yang
modified 12 May 2013
by D. Cuartielles
This example is in the public domain
// initialize the robot
Robot.begin();
Robot.motorsWrite(255, 255); // move forward --On this line
delay(2000);
Robot.motorsStop(); // fast stop
Robot.motorsWrite(-255, -255); // backward
Robot.motorsWrite(0, 0); // slow stop
Robot.motorsWrite(-255, 255); // turn left
delay(2000);
Robot.motorsWrite(255, -255); // turn right
delay(2000);
can anyone see if they can figure out why it is saying this
Are you forgetting to include a library? Maybe look closely at the Robot library examples.
