Not declared in this scope
My code is as follows:
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
byte data = 0;
// pin for the button switch
int button = 7;
// value to check state of button switch
int pressed = 0;
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(button, INPUT);
randomSeed(analogRead(0));
void shiftWrite(int desiredPin, boolean desiredState) {
bitWrite(data,desiredPin,desiredState);
digitalWrite(latchpin, HIGH);
shiftOut(dataPin, clockPin, data);
digitalWrite(latchpin, LOW);
void buildUpTension() {
  // light LEDs from left to right and back to build up tension
  // while waiting for the dice to be thrown
  // left to right
  for (int i=0; i<=19; i++) {
    if (i!=0) {
      digitalWrite(i-1, LOW);
    digitalWrite(i, HIGH);
    delay(100);
  // right to left
  for (int i=19; i>=0; i--) {
    if (i!=19) {
      digitalWrite(i+1, LOW);
    delay(100);
void showNumber(int number) {
  shiftWrite(0, HIGH);
  if (number >= 2) {
    shiftWrite(1, HIGH);
  if (number >= 3) {
    shiftWrite(2, HIGH);
  if (number >= 4) {
    shiftWrite(3, HIGH);
  if (number >= 5) {
    shiftWrite(4, HIGH);
  if (number >= 6) {
    shiftWrite(5, HIGH);
  if (number >= 7) {
    shiftWrite(6, HIGH);
  if (number >= 8) {
    shiftWrite(7, HIGH);
  if (number >= 9) {
    shiftWrite(8, HIGH);
  if (number >= 10) {
    shiftWrite(9, HIGH);
  if (number >= 11) {
    shiftWrite(10, HIGH);
  if (number >= 12) {
    shiftWrite(11, HIGH);
  if (number >= 13) {
    shiftWrite(12, HIGH);
  if (number >= 14) {
    shiftWrite(13, HIGH);
  if (number >= 15) {
    shiftWrite(14, HIGH);
  if (number >=16) {
    shiftWrite(15, HIGH);
  if (number >= 17) {
    shiftWrite(16, HIGH);
  if (number >= 18) {
    shiftWrite(17, HIGH);
  if (number >= 19) {
    shiftWrite(18, HIGH);
  if (number == 20) {
    digitalWrite(19, HIGH);
int throwDice() {
  // get a random number in the range [1,6]
  int randNumber = random(1,21);
  return randNumber;
void setAllLEDs(int value) {
    digitalWrite(i, value);
pressed = digitalRead(button);
  if (pressed == HIGH) {
    // remove previous number
    setAllLEDs(LOW);
    buildUpTension();
    int thrownNumber = throwDice();
    showNumber(thrownNumber);
And I'm getting the following error messages:
Arduino: 1.8.1 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Eva\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10801 -build-path C:\Users\Eva\AppData\Local\Temp\arduino_build_731308 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Eva\Documents\Arduino\random_number_composite\_3p_composite\_3p_composite.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Eva\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10801 -build-path C:\Users\Eva\AppData\Local\Temp\arduino_build_731308 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Eva\Documents\Arduino\random_number_composite\_3p_composite\_3p_composite.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Eva\AppData\Local\Temp\arduino_build_731308\sketch\_3p_composite.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Eva\AppData\Local\Temp\arduino_build_731308\sketch\_3p_composite.ino.cpp" -o "C:\Users\Eva\AppData\Local\Temp\arduino_build_731308\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Eva\AppData\Local\Temp\arduino_build_731308\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Eva\AppData\Local\Temp\arduino_build_731308\sketch\_3p_composite.ino.cpp" -o "C:\Users\Eva\AppData\Local\Temp\arduino_build_731308\sketch\_3p_composite.ino.cpp.o"
C:\Users\Eva\Documents\Arduino\random_number_composite\_3p_composite\_3p_composite.ino: In function 'void shiftWrite(int, boolean)':
_3p_composite:26: error: 'latchpin' was not declared in this scope
_3p_composite:27: error: too few arguments to function 'void shiftOut(uint8_t, uint8_t, uint8_t, uint8_t)'
In file included from C:\Users\Eva\AppData\Local\Temp\arduino_build_731308\sketch\_3p_composite.ino.cpp:1:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:147:6: note: declared here
 void shiftOut(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder, uint8_t val);
exit status 1
I have read a few other posts from people getting error messages about variables not being declared in this scope, but I still can't seem to find where the problem is in my own code. If anyone knows what I'm doing wrong, or knows where I can find an explanation, I would really appreciate it!
Change to:
latchPin
Thank you so much. I feel very silly for missing that.
