Not Displaying Bitmaps?
hey when trying to display a full black page on my screen i always have an error and it not all show up as black the other images are fine its just a solid black page that files when using bitmap
i get this error when compiling Binary sketch size: 3384 bytes (of a 30720 byte maximum) avrdude: verification error, first mismatch at byte 0x0b80 0xff != 0xfe avrdude: verification error; content mismatch
the image is
static const byte th_b00001[] = {
  /* page 0 (lines 0-7) */
  0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  /* page 1 (lines 8-15) */
  /* page 2 (lines 16-23) */
  /* page 3 (lines 24-31) */
  /* page 4 (lines 32-39) */
  /* page 5 (lines 40-47) */
  0xff,0xff,0xff,0x00,
Among the things you haven't mentioned are: 1) Your processor type 2) Your sketch
0xff != 0xfe
Maybe you've exhausted your flash.
Arduino Demunulative
nokia 5110 screen
full code for displaying
#include <PCD8544.h>
#include "th_b00001.h"
// The dimensions of the LCD (in pixels)...
static const byte LCD_WIDTH = 84;
static const byte LCD_HEIGHT = 48;
// pictures dimensions
static const byte bad_w =84;
static const byte bad_h = 48;
static PCD8544 lcd;
  lcd.begin(LCD_WIDTH, LCD_HEIGHT);
  lcd.clear();
    lcd.setCursor(0,0);
  lcd.drawBitmap(th_b00001, bad_w, bad_h);
0xef comes out with lines in :frowning:
'0xef comes out with lines in'
Do you just type in random words in the hope that some will form a sentence?
no.
when i change it all to 0xfe on the display it has a black page with lines in -.-
i think it may be the converter im using. how do i get the VB.NET converter working?
http://www.arduino.cc/playground/Code/PCD8544 the one on there?
Well, first, you define "working" and then you figure out how that definition differs from what you observe.
I'd probably go with the Java version, and figure out how to make it look more like Processing.
how do i put it into visual basic ( i think thats the code ) tried java that did not work either
Do you know VB.NET? Do you know Visual Basic?
If the answer to either of these questions is "no", you've got some learning to do.
no and no. just how do i fix the problem. is there another bmp to hex i can try?
There's the one you could write in Processing
where?
where?
In the Processing IDE, where else?
i dont know how. just how can i get it working?
From the sound of it, this is simply beyond your skill level at this point.
As AWOL pointed out, you should probably follow some basic tutorials in a programming language first, so you can grasp the fundamentals on why it doesn't work the way you expect it to, how you can approach the problem, where to go when you can't fix it yourself to get some help and ultimately to fix the problem. Possible languages you can use to easily convert your image: php python (both of these have excellent documentation, and plenty of tutorials aimed at beginners)
I'm not entirely sure, but I do believe java is quite capable of this too? Though I'm afraid I'd have to look at somebody else to confirm this.
One of the examples is in Java.
I don’t know Java, but the example looks straightforward.
I think it would be easy to transcribe into Processing.
so i have just wasted £20 on a screen? im trying to fix the code with my current conveter. its just a hex converter i need
'so I just wasted £20 on a screen'
No, why ever would you think that? You've been given plenty of advice, so quit whining and start doing. Why are you trying to make this sound like our problem, and slap us with your guilt?
ok i have the code now, i saw on the playground theres the part of displaying it on an lcd via serial . how do i do it manuly
Can you explain in clear English what you are trying to do?
