In my project I am running an LCD, Potentimeter, DHT11, Stepper Motor, and Servo ALL on the same 5V pin in my arduino UNO. Becuase the Servo is the last pin in order on the bread board, it isn't going the speed I am coding it to go. Any suggestions on how to add another power source to another bread board row??
Just buy a power supply with sifficient current capabilities and the correct voltage. Or look in your junkbox for an old computer power supply.
Disconnect the 5V between Arduino and breadboard (leave the GND in place) and connect GND and 5V of the new power supply to the breadboard.
Thanks Delta, I will try to use a 9v battery hooked up to a power supply and switch the jumper to 5v.
"Those square looking 9V just don't have enough juice in them for stuff like this. "
Nor are they designed to output current at the levels servos can require.
Alright, my power supply allows up to 12v so how many AA batterys can i connect to it for at most 12v.
