not enough pressure
Newbie here. I'm setting up an irrigation system using Arduino Uno, relays and three solenoids. I live out in the country and my water pressure is minimal and so I cannot irrigate all three zones at once. When solenoid A is open I need B and C to be closed. Once A is satisfied, then move on to B and close A and C.
Etc. It is probably simple enough but for a retired person with no electronic background, I cannot get my head around it.
I hope I have given you enough information. If not please do not hesitate to ask for more. The code follows.
I thank you in advance.
Pax2
const int sensorValueA = A0;
const int sensorValueB = A1;
const int sensorValueC = A2;
const int solenoidA = 13;
const int solenoidB = 12;
const int solenoidC = 11;
// read the input on 3 analog pins:
//analogRead(sensorValueA); Serial.println(sensorValueA);
//analogRead(sensorValueB); Serial.println(sensorValueB);
//analogRead(sensorValueC); Serial.println(sensorValueC);
pinMode(solenoidA, OUTPUT);
pinMode(solenoidB, OUTPUT);
pinMode(solenoidC, OUTPUT);
  int outputValueA;
  int humidityRealA;
  int outputValueB;
  int humidityRealB;
  int outputValueC;
  int humidityRealC;
  outputValueA= analogRead(sensorValueA);
  humidityRealA = map(outputValueA, 1023, 200, 0, 100);
  outputValueB= analogRead(sensorValueB);
  humidityRealB = map(outputValueB, 1023, 250, 0, 100);
  outputValueC= analogRead(sensorValueC);
  humidityRealC = map(outputValueC, 1023, 270, 0, 100);
  Serial.print ("Sorsor A  ");
  Serial.print(humidityRealA);
  Serial.println ("%");
  delay (500);
   Serial.print ("Sorsor B  ");
  Serial.print(humidityRealB);
   delay (500);
   Serial.print ("Sorsor C  ");
  Serial.print(humidityRealC);
  digitalWrite(solenoidA, LOW);
  digitalWrite(solenoidB, LOW);
  digitalWrite(solenoidC, LOW);
   if (humidityRealA < 60)
    digitalWrite(solenoidA, HIGH);
    else if (humidityRealA > 85){
    digitalWrite(solenoidA, LOW); }
     if (humidityRealB < 60)
    digitalWrite(solenoidB, HIGH);
    else if (humidityRealB > 85){
    digitalWrite(solenoidB, LOW); }
     if (humidityRealC < 60)
    digitalWrite(solenoidC, HIGH);
    else if (humidityRealC > 85){
    digitalWrite(solenoidC, LOW); }}
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Add a variable that can keep track of which zone needs to be done. Every time a zone is humid enough, change to the next zone. I think that the below will work; I've chosen what seem to be sensible values (letters) for the zones.
Not tested but does compile.
  // keep track of the zone; start with A
  static char zone = 'A';
  int outputValueA;
  int humidityRealA;
  int outputValueB;
  int humidityRealB;
  int outputValueC;
  int humidityRealC;
  outputValueA = analogRead(sensorValueA);
  outputValueB = analogRead(sensorValueB);
  outputValueC = analogRead(sensorValueC);
  delay (500);
  delay (500);
  if (zone == 'A')
      zone = 'B';
  else if (zone == 'B')
      zone = 'C';
  else if (zone == 'C')
      zone = 'A';
    // invalid zone
Thank you very much for the reply. The sketch does compile and it does switch zone as intended.
