Not equal problem
Hi
When I change Voltage on A0, U1 should show same thing but I have all the time zero - 0
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //uno
float V = 0;
int U1;
  pinMode(A0, INPUT);
  lcd.begin(16, 2);
  V = analogRead(A0);
  V = V / 1024 * 5.0;
  if (V != V)
    U1 = V;
  Serial.print("V= ");
  Serial.print(V);
  Serial.print("     U1= ");
  Serial.println(U1);
  lcd.setCursor(6, 1); //Place the cursor at Line 1, Column 6. From here the
  lcd.print(V, 1); //Print the number of val on the LCD
  lcd.print("V");
  delay(100);
Analog read return an integer, not a float. Read the documentation!
Paul
You sure about that?
not, that why I marked this part
How can V be not equal to V?
now is working
Thanks
if (currentV != V)
U1 = V;
See Reply #2. Don't attempt to compare equality or inequality on float variables.
now is working, with this I have all zeros
int V;
Actually, it doesn't work at all. The variable 'currentV' is undefined in the code you posted. So, it doesn't even compile.
I added also
float currentV;
We can't see your code
Like I said.
float V = 0;
float U1;
float currentV;
  pinMode(A0, INPUT);
  lcd.begin(16, 2);
  V = analogRead(A0);
  V = V / 1024 * 5.0;
  if (currentV != V)
    U1 = V;
  Serial.print(V);
  Serial.println(U1);
  lcd.print("V");
  delay(100);
currentV has the value 0.0, as does U1
here you are
And after that, you never change the value of currentV
when I changing U1 is following V
