This might be a very stupid question, but i spent a lot of time and still couldn't spot the mistake. I'm using an ESP-32 chip, and here is part of the code:
void reader(void *pvParameters) {
uint16_t read_sum[1024];
size_t read_sum_sz = sizeof(read_sum);
uint16_t count = 0;
uint8_t * read_sum_pt = (uint8_t *)&read_sum;
//String for_send;
// The 4 high bits are the channel, and the data is inverted
uint16_t offset = (int)ADC_INPUT * 0x1000 + 0xFFF;
size_t bytes_read;
while (1) {
uint16_t buffer[2] = {0};
i2s_read(I2S_NUM_0, &buffer, sizeof(buffer), &bytes_read, 15);
//Serial.printf("%d %d %d\n", offset - buffer[0], offset - buffer[1],offset - buffer[2]);
if ((bytes_read == sizeof(buffer)) && (is_client == 1)) {
read_sum[count] = offset - buffer[0];
if (count >= 1023) {
webSocket.sendBIN(0, read_sum_pt, read_sum_sz);
count = 0;
count++;
//for_send = int64String(read_sum);
//webSocket.sendTXT(0, for_send);
Serial.println("buffer empty");
it continuously generates these error:
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:928
ho 0 tail 12 room 4
load:0x40078000,len:8424
ho 0 tail 12 room 4
load:0x40080400,len:5868
entry 0x4008069c
0
abort() was called at PC 0x400861dd on core 1
Backtrace: 0x4008c948:0x3ffbe370 0x4008cb79:0x3ffbe390 0x400861dd:0x3ffbe3b0 0x40086309:0x3ffbe3e0 0x400e9dbf:0x3ffbe400 0x400e5c39:0x3ffbe6c0 0x400de3a4:0x3ffbe710 0x4008a019:0x3ffbe740 0x40089795:0x3ffbe770 0x400814ea:0x3ffbe790 0x400818f1:0x3ffbe7c0 0x4000bfed:0x3ffb1c20 0x4008a16d:0x3ffb1c30 0x4008a2f3:0x3ffb1c50 0x4008a376:0x3ffb1c70 0x400d58d7:0x3ffb1cb0 0x400d28dd:0x3ffb1ce0 0x400d2d04:0x3ffb1d10 0x400d2e25:0x3ffb1e10 0x400d2f03:0x3ffb1e30 0x400d1e91:0x3ffb1f60 0x400d6287:0x3ffb1fb0 0x400888e5:0x3ffb1fd0
Rebooting...
ets Jun 8 2016 00:22:57
The problem is related to the count variable, if i comment count++; out or add a line of count=0; right after it, there is no error. Looks like some kind of overflow problem, but by default this condition if ((bytes_read == sizeof(buffer)) && (is_client == 1)) is false, the count++ shouldn't even be executing. I tried to replace count++ by a print function, it doesn't execute.
Here are a few extra info might be relevant:
- The reason I noticed this is because the if code was a little different before, and that version generates an error of overflow in this function. That version is overwritten, now I cannot regenerate that error.
- I use xTaskCreatePinnedToCore to run this funcion on core0, it's a little weird the abort() is called by core1, where the main loop and the rest of the program runs on.
Am I making some fundamental mistakes here or this goes deep into the SoC's part?
