NOT getting how to use SERIAL PORT as a passkey INPUT
Hello World ,
I am recently facing a problem in a program in which I have to take input from the user using the Serial port but i am not able to process the input properly
PLEASE HELP ME!!
String pass=0;
   pinMode(13,OUTPUT);
   if(Serial.available()>0)
   pass=Serial.read();
    if(pass=="1234")
    Serial.println("Correct passkey");
    digitalWrite(13,HIGH);
   else if(pass!="1234")
   Serial.println("Incorrect passkey");
Serial.read(); reads a single character so what is read will never equal "1234"
Have a look at the Serial.readStringUntil() function
Even better, look at Serial input basics - updated and don't use Strings at all
Simple serial echo test code that captures characters and sends them back to the serial monitor.
//zoomkat 6-29-14 Simple serial echo test
//type or paste text in serial monitor and send
String readString;
  Serial.println("Simple serial echo test"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the String readString
    delay(3);  //slow looping to allow buffer to fill with next character
  if (readString.length() > 0) {
    Serial.println(readString);  //so you can see the captured String
    readString = "";
